Port forwarding not working. Minecraft Bedrock Server
Hi guys,
I am an ordinary user and I am trying to run a Minecraft Bedrock server for a couple of friends. The server is running but no one from WAN can reach it. Only from LAN.
I tried port forwarding and firewall filter rule but with no success. When I try to ping the port 13192 it appears to be closed. I use ping.eu if it matters.
So please help.
Thank you in advance!
conf.rsc (5.38 KB)
Upgrade your firmware its dated, use long term version 6.47.9
From
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=dst-nat chain=dstnat dst-port=19132 in-interface=ether1
in-interface-list=WAN protocol=tcp src-port=19132 to-addresses=
192.168.88.172 to-ports=19132
add action=dst-nat chain=dstnat disabled=yes dst-port=19132 in-interface=
ether1 protocol=tcp to-addresses=192.168.88.172 to-ports=19132
TO
in-interface-list=WAN protocol=tcp to-addresses=
192.168.88.172
(Note: dont need to ports if same as dst-port)
Ensure this line in your winbox has DNS selected.
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1 dns-server=192.168.88.1
These input rules need work, the one in red looks more like a nat rule in the wrong place…
{forward chain seem seems OK}
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
{input chain needs work}
add action=accept chain=input connection-state=
add action=drop chain=input connection-state=
invalid
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
disabled=yes in-interface-list=!LAN
This rule needs to be removed.
add action=accept chain=forward dst-address=192.168.88.172 dst-port=19132
protocol=tcp
@anav
you are doing such a great job by helping so many people.
I made the changes you proposed (except the firmware upgrade) but the 19132 port is still closed.
I am attaching the new config file.
conf_v1.rsc (3.48 KB)
(1) Didnt make this change LOL should be bridge.
add address=192.168.88.1/24 comment=defconf interface=ether2 network=
192.168.88.0
(2) not a pppoe guy but shouldnt the dhcp client be the pppoe interface??
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
(3) Missing an important default input chain firewall rule for security.
(4) Other than that I cannot see anything ??? Once you have changed the above give it a try.
If still doesn’t work disable UPNP and see if that helps (clutching at straws LOL)
Finally, can you confirm you get a public IP address at the router?? If you get a private IP it would be impossible to port forward unless the router ahead of you forwards all ports to your Router.
(5) Suggest you re order your rule so they are easier to read and thus not screw up.
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add chain=forward comment=“defconf: accept in ipsec policy”
