Good Day All
Just plugged in my hAP ax2 and got internet and wifi working without any issues. Moving over from a Tenda router that is resetting every 5 minutes.
Next step is to get my home assistant server talking working on my phone from internally and externally using port forwarding. This was working fine on the tenda:
The important one right now is 192.168.0.220:8123 from external 443
209 = raspberry pi with pihole and wireguard. that will be next.
My issue currently is that this works perfect if I switch my phone over to LTE and I try to access the home assistant server from outside network using DuckDNS
But on Wifi I cannot access home assistant server unsing external IP or DuckDNS given name. I can access it fine obviously using the 192.168.0.220:8123 from internally.
This is most probably some setting to allow from inside network? but am uncertain on how to do this. Help will be greatly appreciated.
My Firewall rules are as per AX2 out of the box with just routerOS updated to 7.10.2
port mapping was just done basically as per quickset:
My config:
# 2023-07-14 09:34:08 by RouterOS 7.10.2
# software id = **ELIDED**
# model = C52iG-5HaxD2HaxD
# serial number = **ELIDED**
add admin-mac=48:A9:8A:7A:D8:D6 auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.country="South Africa" .mode=ap .ssid=tangmonster0 \
disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip kid-control
add fri=0s-1d mon=0s-1d name=system-dummy sat=0s-1d sun=0s-1d thu=0s-1d tue=\
0s-1d tur-fri=0s-1d tur-mon=0s-1d tur-sat=0s-1d tur-sun=0s-1d tur-thu=\
0s-1d tur-tue=0s-1d tur-wed=0s-1d wed=0s-1d
add name=dhcp ranges=192.168.0.100-192.168.0.200
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/ipv6 settings
set max-neighbor-entries=15360
add address=192.168.0.210/24 comment=defconf interface=bridge network=\
192.168.0.0
/ip dhcp-client
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.209 gateway=\
192.168.0.210 netmask=24
set allow-remote-requests=yes servers=192.168.0.209
/ip dns static
add address=192.168.0.210 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment="home assistant" dst-port=443 \
in-interface-list=WAN log=yes log-prefix=dusckdnshomeassistant protocol=\
tcp to-addresses=192.168.0.220 to-ports=8123
add action=dst-nat chain=dstnat comment="home assistant port 3000" dst-port=\
3000 in-interface-list=WAN protocol=tcp to-addresses=192.168.0.220 \
to-ports=3000
add action=dst-nat chain=dstnat comment=wireguard dst-port=51822 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.0.209 to-ports=\
51822
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Africa/Johannesburg
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
please let me know what other information I need to provide.
