Hi everyone, I’m having some trouble setting up a port forwarding over a wireguard tunnel.
Here’s my network diagram
Router R2 is connecting using an E3372 LTE dongle that has no public IP, I would like to use public IP from R1 and setup a port forwarding rule, so I can access the HTTP server behind R2 using public IP from R1
Currently I can access R2 HTTP server from the computer within the LAN of R1 (using LAN IP from R2) , but when I try to access it from another computer (different network) using R1’s public IP, that didn’t work.
I also tried setting up mangle rules on R2, but I don’t think that is working, or maybe my rules are wrong ?
Hope someone can help me shed some light on this issue. Thanks
Here are my router configs, both R1 and R2
# 2024-05-14 23:12:31 by RouterOS 7.14.3
# model = RB960PGS
# Router R1
add admin-mac=<Redacted> auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
/interface wireguard
add listen-port=13231 mtu=1420 name=wg-lte
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
1111@example.com
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=sfp1 internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
add comment=defconf disabled=yes interface=ether1 list=WAN
/interface wireguard peers
add allowed-address=172.22.1.0/24,10.10.0.0/24,0.0.0.0/0 interface=wg-lte \
public-key="<Redacted>"
192.168.88.0
add address=172.22.1.1/24 interface=wg-lte network=172.22.1.0
/ip dhcp-client
192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
established,related,untracked
invalid
add action=accept chain=input dst-port=13231 protocol=udp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat dst-port=1111 in-interface=pppoe-out1 \
protocol=tcp to-addresses=10.10.0.60 to-ports=8080
add disabled=no dst-address=10.10.0.0/24 gateway=172.22.1.2 routing-table=\
main suppress-hw-offload=no
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Asia/Taipei
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
# 2024-05-14 23:09:22 by RouterOS 7.14.3
# model = RBD52G-5HacD2HnD
# R2 LTE Router
add listen-port=13231 mtu=1420 name=wg-pubip
/ip hotspot profile
add name=default-dhcp ranges=10.10.0.10-10.10.0.60
/routing table
add disabled=no fib name=to-wg
add interface=lte1 list=WAN
add allowed-address=172.22.1.0/24,192.168.88.0/24,0.0.0.0/0 endpoint-address=\
<Redacted> endpoint-port=13231 interface=wg-pubip public-key=\
<Redacted>
add address=10.10.0.254/24 comment=defconf interface=bridge network=10.10.0.0
add address=172.22.1.2/24 interface=wg-pubip network=172.22.1.0
/ip dhcp-client
add address=10.10.0.0/24 comment=defconf dns-server=10.10.0.254 gateway=\
10.10.0.254
invalid
/ip firewall mangle
add action=mark-connection chain=prerouting in-interface=wg-pubip \
new-connection-mark=from-wg-conn passthrough=yes
add action=mark-routing chain=prerouting connection-mark=from-wg-conn \
new-routing-mark=to-wg passthrough=no
add disabled=no dst-address=192.168.88.0/24 gateway=172.22.1.1 routing-table=\
add disabled=no dst-address=0.0.0.0/0 gateway=172.22.1.1 routing-table=to-wg \
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/system clock
/system note
/tool mac-server
