This should be a simple problem. I’ve been pounding my head against it for a couple of weeks. Hopefully someone here can spot my mistake and help me out.
I’m trying to forward port 80 (http) and 23 (telnet) from the external WAN interface through to an internal IP (10.1.1.2). I have port forwarding working to a different internal VNC server (10.1.1.50).
When I try to locally access 10.1.1.2 via port 80 or 23 it works well. I am assured that there are no ACLs on 10.1.1.2 and that its default gateway is configured correctly.
ROS v5.23 x86 platform
/ip firewall address-list
add address=83.15.210.114 disabled=yes list=hax0rs
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=masquerade chain=srcnat disabled=no src-address=10.1.1.0/24
add action=masquerade chain=srcnat comment="IPs on CMTS Network" disabled=no \
src-address=10.2.1.0/24
add action=masquerade chain=srcnat disabled=no src-address=10.3.1.0/24
add action=dst-nat chain=dstnat comment="TV Guide Computer - VNC" disabled=no \
dst-address=w.x.y.z dst-port=5900 protocol=tcp to-addresses=\
10.1.1.50 to-ports=5900
dst-address=w.x.y.z dst-port=5800 protocol=tcp to-addresses=\
10.1.1.50 to-ports=5800
add action=dst-nat chain=dstnat comment=\
"Port forward to allow web access to the CMTS" disabled=no dst-address=\
w.x.y.z dst-port=80 protocol=tcp to-addresses=10.1.1.2 to-ports=80
"Port forwarding to allow remote access to the CMTS from the internet" \
disabled=no dst-address=w.x.y.z dst-port=9090 protocol=tcp \
disabled=no dst-address=w.x.y.z dst-port=23 protocol=tcp \
to-addresses=10.1.1.2 to-ports=23
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
