Hi everyone,
I have an RB5009 with some vlans configured and want to do some port forwarding. Unfortunately is not working. I have a pretty standard config with some separation of the nsfw vlan:
# jul/07/2022 15:21:38 by RouterOS 7.3
# software id = BRXK-M2RB
# model = RB5009UG+S+
# serial number = <CENSORED>
add admin-mac=DC:2C:6E:66:49:2F auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
<CENSORED>
/interface vlan
add interface=bridge name=vlan10-vm vlan-id=10
add interface=bridge name=vlan15-home vlan-id=15
add interface=bridge name=vlan20-nsfw vlan-id=20
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp-ethernet ranges=192.168.1.150-192.168.1.254
add name=dhcp-home ranges=192.168.15.150-192.168.15.254
add name=dhcp-nsfw ranges=192.168.20.150-192.168.20.254
add add-arp=yes address-pool=dhcp-ethernet interface=bridge name=ethernet
add add-arp=yes address-pool=dhcp-home interface=vlan15-home name=home
add add-arp=yes address-pool=dhcp-nsfw interface=vlan20-nsfw name=nsfw
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
identity=<CENSORED> name=zt1 \
port=9993
/zerotier interface
add allow-default=no allow-global=no allow-managed=yes disabled=no instance=\
zt1 name=zerotier1 network=<CENSORED>
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8 pvid=20
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge interface=vlan10-vm
add bridge=bridge interface=vlan15-home
add bridge=bridge interface=vlan20-nsfw
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge tagged=bridge,ether6,ether7,ether2 untagged=ether8 \
vlan-ids=20
add bridge=bridge tagged=bridge,ether6,ether7,ether2 vlan-ids=15
add bridge=bridge tagged=bridge,ether6,ether7,ether2 vlan-ids=10
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=\
LAN wan-interface-list=WAN
add interface=zerotier1 list=LAN
add interface=vlan15-home list=LAN
add interface=vlan20-nsfw list=LAN
add interface=vlan10-vm list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
192.168.1.0
add address=192.168.10.1/24 interface=vlan10-vm network=192.168.10.0
add address=192.168.15.1/24 interface=vlan15-home network=192.168.15.0
add address=192.168.20.1/24 interface=vlan20-nsfw network=192.168.20.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
192.168.1.1 netmask=24
add address=192.168.15.0/24 dns-server=192.168.15.1 gateway=192.168.15.1
add address=192.168.20.0/24 dns-server=192.168.20.1 gateway=192.168.20.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8,9.9.9.9
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add action=drop chain=input in-interface=vlan20-nsfw protocol=tcp
add action=drop chain=forward connection-state=!established,related \
in-interface=vlan20-nsfw out-interface-list=LAN protocol=tcp
established,related,untracked
invalid
add action=accept chain=input comment="defconf: accept ICMP" \
in-interface-list=LAN protocol=icmp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat dst-port=48552 protocol=tcp to-addresses=\
192.168.10.100 to-ports=48552
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Bucharest
/system routerboard settings
set cpu-frequency=1400MHz
/tool mac-server
/tool mac-server mac-winbox
Disabling the following rules does not make any difference:
Any help is appreciated
