Question;
I’m not on my feet yet with Dude and Mikrotik CLI so what I would like is a way to get into a remote office Hex webfig through a Cloud Hosted RouterOS LAN IP. I thought I could do some basic port forwarding in the CHR LAN to the remote Hex Wireguard virtual IP but it isn’t working, what am I doing wrong?
I’m not sure if this NAT rule in CHR is correct;
General;
Chain; dstnat
Protocol; tcp
dst port; 24701 (I randomly picked some unused IANA space)
In interface list; all
Action
Action; dst-nat
to address; 10.50.1.1
to port; 80 (also tried 443, has a cert and is enabled in the hex)
Error; http://192.168.140.130:24701 == ERR_CONNECTION_TIMED_OUT
Situation;
I have a central Cloud Hosted RouterOS, that hosts wireguard VPN and Dude server. This has public static IP I can work with, and the CHR itself sits on a LAN IP behind our data center main firewall.
Remote office has a Hex behind a firewall I don’t control and dynamic IP. This is connecting via wireguard back to central Router OS and they can ping each other via the wireguard virtual IP. Also CHR Dude server can connect to the remote Hex via that wireguard virtual IP.
Remote Hex has a firewall rule allowing this;
Comment; Allow Config over VPN
Chain; input
Src Address; 10.0.0.0/8 (covers both OpenVPN running on 10.8.0.x and should cover Wireguard on 10.50.0.x)
Protocol; tcp
Dst port; 80,443,8291
Two comments on this rule;
-Dude can reach this router over the Wireguard VPN from CHR, dude is looking at address 10.50.1.1
-Also Openvpn connection from this router to another system that I can reach the webfig in this Hex over that OpenVPN 10.8.0.14 virtual address.
CHR firewall rule
Comment; Allow Config over LAN
chain; input
src address; 192.0.0.0/8 (I can reach this webfig over our office LAN, but not internet == good)
protocol; tcp
dst port; 80,443,8291,24700-24800 (I modified this and added the high numbers, I randomly picked some unused IANA space)
action; acept
Basic Ping testing between CHR and remote Hex looks good to me;
[user@remoteRouterOS] > ping 10.50.1.254 (this is the wireguard interface in the CHR)
SEQ HOST SIZE TTL TIME STATUS
0 10.50.1.254 56 64 27ms818us
1 10.50.1.254 56 64 27ms233us
2 10.50.1.254 56 64 27ms876us
Inside the CHR it can reach out through wireguard to ping the Hex and Dude can use this to read the remote Hex router.
[user@CHR] > ping 10.50.1.1
0 10.50.1.1 56 64 26ms876us
1 10.50.1.1 56 64 27ms33us
2 10.50.1.1 56 64 27ms192us
