Hi All,
I’m having some issues getting my port forwarding working for a Netatamo presence. A quick google search turned up some requirement for udp on ports 500 and 4500. I have obtained the IP and applied a static IP. I added 2 entries to the NAT table however this wasn’t sufficient. So searching through the various post here I determined that my rules might be the issue. however I suspect I have added some that maybe that maybe contradictory and I’ve become somewhat lost in the process. The router had been work fine with the rule I’ve had in place for a couple of years. I’ve never really required port forwarding and it was always about applying restrictive DNS entries for my kids. Anyway I have grabbed an export and I was hoping someone here might spot the issues. I really appreciate any advice.
[superuser@MikroTik] /ip firewall> export
# nov/27/2019 18:46:21 by RouterOS 6.45.6
# software id = TVH9-PQU5
# model = 2011UiAS
# serial number = 75B80616B2A1
add action=drop chain=forward src-address=0.0.0.0/8
add action=drop chain=forward dst-address=0.0.0.0/8
add action=drop chain=forward src-address=127.0.0.0/8
add action=drop chain=forward dst-address=127.0.0.0/8
add action=drop chain=forward src-address=224.0.0.0/3
add action=drop chain=forward dst-address=224.0.0.0/3
add chain=forward comment="Allow connections from the LAN" connection-state=new in-interface=\
bridge1_LAN
add action=accept chain=forward connection-nat-state=dstnat
add chain=forward comment="Allow established connections" connection-state=established
add chain=forward comment="Allow related connections" connection-state=related
add action=jump chain=forward disabled=yes jump-target=tcp protocol=tcp
add action=jump chain=forward disabled=yes jump-target=udp protocol=udp
add action=jump chain=forward disabled=yes jump-target=icmp protocol=icmp
add action=drop chain=tcp comment="deny TFTP" dst-port=69 protocol=tcp
add action=drop chain=tcp comment="deny RPC portmapper" dst-port=111 protocol=tcp
add action=drop chain=tcp comment="deny RPC portmapper" dst-port=135 protocol=tcp
add action=drop chain=tcp comment="deny NBT" dst-port=137-139 protocol=tcp
add action=drop chain=tcp comment="deny cifs" dst-port=445 protocol=tcp
add action=drop chain=tcp comment="deny NFS" dst-port=2049 protocol=tcp
add action=drop chain=tcp comment="deny NetBus" dst-port=12345-12346 protocol=tcp
add action=drop chain=tcp comment="deny NetBus" dst-port=20034 protocol=tcp
add action=drop chain=tcp comment="deny BackOriffice" dst-port=3133 protocol=tcp
add action=drop chain=tcp comment="deny DHCP" dst-port=67-68 protocol=tcp
add action=drop chain=udp comment="deny TFTP" dst-port=69 protocol=udp
add action=drop chain=udp comment="deny PRC portmapper" dst-port=111 protocol=udp
add action=drop chain=udp comment="deny PRC portmapper" dst-port=135 protocol=udp
add action=drop chain=udp comment="deny NBT" dst-port=137-139 protocol=udp
add action=drop chain=udp comment="deny NFS" dst-port=2049 protocol=udp
add action=drop chain=udp comment="deny BackOriffice" dst-port=3133 protocol=udp
add action=accept chain=icmp comment="echo reply" icmp-options=0:0 protocol=icmp
add action=accept chain=icmp comment="net unreachable" icmp-options=3:0 protocol=icmp
add action=accept chain=icmp comment="host unreachable" icmp-options=3:1 protocol=icmp
add action=accept chain=icmp comment="host unreachable fragmentation required" icmp-options=3:4 \
protocol=icmp
add action=accept chain=icmp comment="allow source quench" icmp-options=4:0 protocol=icmp
add action=accept chain=icmp comment="allow echo request" icmp-options=8:0 protocol=icmp
add action=accept chain=icmp comment="allow time exceed" icmp-options=11:0 protocol=icmp
add action=accept chain=icmp comment="allow parameter bad" icmp-options=12:0 protocol=icmp
add action=drop chain=icmp comment="deny all other types"
add action=reject chain=forward comment="drop facebook" content=facebook.com disabled=yes dst-port=\
80,443 protocol=tcp reject-with=icmp-admin-prohibited src-address=192.168.10.5
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=WAN
add action=accept chain=forward connection-nat-state=dstnat dst-address=139.168.10.30 dst-port=500,4500 \
protocol=udp
add action=dst-nat chain=dstnat dst-port=53 protocol=tcp src-address=192.168.10.100-192.168.10.254 \
to-addresses=192.168.10.50 to-ports=53
add action=dst-nat chain=dstnat dst-port=53 protocol=udp src-address=192.168.10.100-192.168.10.254 \
add action=dst-nat chain=dstnat disabled=yes dst-port=10578 in-interface=bridge1_LAN protocol=udp \
to-addresses=192.168.10.162 to-ports=10578
add action=dst-nat chain=dstnat dst-port=4500 in-interface=bridge1_LAN protocol=udp to-addresses=\
192.168.10.30 to-ports=4500
add action=dst-nat chain=dstnat dst-port=500 in-interface=bridge1_LAN protocol=udp to-addresses=\
192.168.10.30 to-ports=500
