Hello!
My router gets dynamic IP from my ISP, so one of the most obvious options is to use DDNS. However when I try to forward SSH port 24022 on my router to port 22 on 192.168.1.240 host inside my local network, connection is either refused or timed out. I lurked this forum a bit, used solutions from similar issues but SSH access doesn’t work anyways.
Port forwarding with dynemic IP / DDNS works if configured correctly. Post NAT config (run /ip firewall nat export in a terminal window) so we can check if something is wrong.
Thank you for the response! Here are my NAT rules:
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none \
out-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=63306 in-interface-list=WAN protocol=tcp to-addresses=\
192.168.1.10 to-ports=3306
add action=dst-nat chain=dstnat dst-port=3724 in-interface-list=WAN protocol=tcp to-addresses=\
192.168.1.10 to-ports=3724
add action=dst-nat chain=dstnat disabled=yes dst-port=24022 in-interface-list=WAN log=yes protocol=t
to-addresses=192.168.1.240 to-ports=22
add action=dst-nat chain=dstnat disabled=yes dst-port=24022 in-interface=ether1 protocol=tcp \
add action=masquerade chain=srcnat disabled=yes out-interface-list=LAN
add action=accept chain=dstnat dst-address=!192.168.1.1 dst-address-type=local dst-port=22 protocol=
src-port=24022 to-addresses=192.168.1.240
add action=accept chain=dstnat dst-address-list=MyDDNS dst-port=22 protocol=tcp src-port=24022 \
Unfortunately, no dstnat rule is working as intended.
And is it public address? It may sound as stupid question, but many people miss this important bit. If you check the address that DDNS hostname resolves to, do you have the same address on your router in IP->Addresses?
Too funny,
One needs a protocol so that the router knows whats coming!
This doesnt cut it…
Sob: Did you want to sign up for my MTUNA certification, we cover 'proper methods in config scrutinization"!
To the OP why do you have so many duplicate looking rules, what a mess!!
Makes me want to slap someone upside the head.
Lets fix it!!
By the way this rule should simply work when you fix the protocol issue!!
Cleaned up working version.
add action=dst-nat chain=dstnat disabled=yes dst-port=24022 in-interface-list=WAN log=yes protocol=tcp \
Done!!
By the way the only reason to use dst-address-list=mywanip
(Assuming mywanip is the firewall address list entry with IP=clouddns name)
If you want to be able to reach the server via your WANIP address from a device on the same lan subnet as your server, if you do two things need to happen.
First add a second hairpin source nat rule.
add action=masquerade chain=srcnat source-address=lansubnet destination-address=lansubnet (in your case lansubnet appears to be 192.168.1.0/24)
Second modify the dst nat rule (replace in-interface-list=WAN) with dst-address=mywanip
@anav: I’d say it’s pretty clear that it was just copy error.
Most likely, but it was a great opportunity for creative writing I could not pass up!!
Note to OP:
Please post complete config as other aspects of the config may be pertinent
Actually… they are very much different, but I didn’t think it should’ve mattered since I was able to connect to my router’s SSH port and HTTP port using personalstring.sn.mynetname.net.
My WAN IP address is in 100.80.0.0/16 subnet. Seems like I am behind my provider’s NAT. How can I actually tune port forwarding?
Note to OP:
[spoiler]
# jul/10/2020 01:27:13 by RouterOS 6.47
# model = RB450Gx4
add admin-mac=B8:69:F4:E5:04:3B auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise="10M-half,10M-full,100M-half,100M-f\
ull,1000M-half,1000M-full,2500M-full,5000M-full,10000M-full" comment=WAN \
loop-protect=on speed=100Mbps
set [ find default-name=ether2 ] advertise="10M-half,10M-full,100M-half,100M-f\
ull,1000M-half,1000M-full,2500M-full,5000M-full,10000M-full" comment=\
ZP-NB loop-protect=on speed=100Mbps
set [ find default-name=ether3 ] advertise="10M-half,10M-full,100M-half,100M-f\
ZP-PC loop-protect=on speed=100Mbps
set [ find default-name=ether4 ] advertise="10M-half,10M-full,100M-half,100M-f\
MAMA-PC speed=100Mbps
set [ find default-name=ether5 ] advertise="10M-half,10M-full,100M-half,100M-f\
"TP-Link AP" poe-out=off speed=100Mbps
/interface pptp-server
add disabled=yes name=XXX user=XXX
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.21-192.168.1.40
add address-pool=dhcp disabled=no interface=bridge lease-time=2d name=defconf
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
/interface detect-internet
set detect-interface-list=all
add address=192.168.1.1/24 comment=defconf interface=ether2 network=\
192.168.1.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1h
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.1.11 client-id=1:8c:89:a5:8:9:fa mac-address=\
8C:89:A5:08:09:FA server=defconf
add address=192.168.1.20 client-id=1:d0:50:99:5d:c3:16 mac-address=\
D0:50:99:5D:C3:16 server=defconf
add address=192.168.1.12 client-id=1:dc:85:de:86:2b:d5 mac-address=\
DC:85:DE:86:2B:D5 server=defconf
add address=192.168.1.10 client-id=1:0:d8:61:54:d7:bc mac-address=\
00:D8:61:54:D7:BC server=defconf
add address=192.168.1.13 client-id=1:94:39:e5:b:b9:a7 mac-address=\
94:39:E5:0B:B9:A7 server=defconf
add address=192.168.1.210 mac-address=00:19:21:68:12:10 server=defconf \
use-src-mac=yes
add address=192.168.1.220 mac-address=00:19:21:68:12:20 server=defconf
add address=192.168.1.221 mac-address=00:19:21:68:12:21 server=defconf
add address=192.168.1.211 mac-address=00:19:21:68:12:11 server=defconf
add address=192.168.1.230 mac-address=00:19:21:68:12:30 server=defconf
add address=192.168.1.231 mac-address=00:19:21:68:12:31 server=defconf
add address=192.168.1.240 mac-address=00:19:21:68:12:40 server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
192.168.1.1 netmask=24 wins-server=192.168.1.1
set allow-remote-requests=yes cache-max-ttl=4w4d cache-size=65536KiB servers=\
8.8.8.8,8.8.4.4
/ip firewall address-list
add address=mystring.sn.mynetname.net list=MyDDNS
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat dst-port=63306 in-interface-list=WAN \
protocol=tcp to-addresses=192.168.1.10 to-ports=3306
add action=dst-nat chain=dstnat dst-port=3724 in-interface-list=WAN protocol=\
tcp to-addresses=192.168.1.10 to-ports=3724
add action=dst-nat chain=dstnat dst-port=24022 in-interface-list=WAN log=yes \
protocol=tcp to-addresses=192.168.1.240 to-ports=22
/ip smb
set domain=HOME enabled=yes interfaces=bridge
/system clock
set time-zone-name=Europe/XXX
/system identity
set name=HOMEBASE
/tool mac-server
/tool mac-server mac-winbox
[spoiler]
Too funny,
This doesnt cut it…add action=dst-nat chain=dstnat disabled=yes dst-port=24022 in-interface-list=WAN log=yes protocol=t
to-addresses=192.168.1.240 to-ports=22Sob: Did you want to sign up for my MTUNA certification, we cover 'proper methods in config scrutinization"!
Makes me want to slap someone upside the head.Lets fix it!!
to-addresses=192.168.1.240 to-ports=22Cleaned up working version.
/ip firewall nat add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none \ out-interface-list=WAN add action=dst-nat chain=dstnat dst-port=63306 in-interface-list=WAN protocol=tcp to-addresses=\ 192.168.1.10 to-ports=3306 add action=dst-nat chain=dstnat dst-port=3724 in-interface-list=WAN protocol=tcp to-addresses=\ 192.168.1.10 to-ports=3724 add action=dst-nat chain=dstnat disabled=yes dst-port=24022 in-interface-list=WAN log=yes protocol=tcp \ to-addresses=192.168.1.240 to-ports=22
Done!!
If you want to be able to reach the server via your WANIP address from a device on the same lan subnet as your server, if you do two things need to happen.First add a second hairpin source nat rule.
add action=masquerade chain=srcnat source-address=lansubnet destination-address=lansubnet (in your case lansubnet appears to be 192.168.1.0/24)Second modify the dst nat rule (replace in-interface-list=WAN) with dst-address=mywanip
It was a copy-paste error, but thanks for an intreresting read anyways =)
If you can reach router using the public address, it must also work for forwarded ports to devices behind router. Do you know what exactly you’re supposed to have? NAT 1:1, i.e. all ports forwarded to you, or just some selected ports? Watch if dstnat rules get any hits. If not, try same ports that previously worked for accessing router.
This is wrong. Your are only the 10th this week with this error.
add address=192.168.1.1/24 comment=defconf interface=> ether2 > network=
192.168.1.0
When using bringing, the IP should be on the bridge (or VLAN if that is used), not one of the interface belongs to the bridge.
Correct
add address=192.168.1.1/24 comment=defconf interface=> bridge > network=
192.168.1.0
You got the DHCP server correct. They should be on the same bridge.
add address-pool=dhcp disabled=no interface=> bridge > lease-time=2d name=defconf
192.168.1.0When using bringing, the IP should be on the bridge (or VLAN if that is used), not one of the interface belongs to the bridge.
Correct
192.168.1.0You got the DHCP server correct. They should be on the same bridge.
Thank you, I’ve corrected the way you’ve suggested! =)
I think this was set by default since I didn’t change much in config.
[/quote]
I most definitely have access to HTTP, SSH, Telnet ports, but I don’t have access to forwarded ports (like src 24022 => dest 22). I get
ssh: connect to host mystring.sn.mynetname.net port 24022: Connection refused
however when I try to connect from the outside, I have no access to anything of these.
Is this double NAT? Where you have to ask your ISP to give you a public IP vice a natted IP?
