Port Forwarding
Bought my first Mikrotik Router Hex S a couple days ago and I can not get port forwarding to work at all. I have watched all the YouTube videos and they each do it a little differently. I have a unraid server running on 192.168.50.29. In there is a docker container called Nginx proxy manager. I am trying to forward ports 80 to port 180 on the docker container and port 443 to 1443 on the docker container. I have changed the Mikrotik Webfig port number to something other than 80 and 443 is currently disabled. I have setup the DSTNAT forwarding rules under nat and have also created the firewall forwarding rules as well. For DST address I am putting the public ip of my router/internet. My internet is coming into my router on ethernet 1. I can not figure out what simple thing I am missing.
I am using the default configuration and haven't changed much besides trying to setup port forwarding.
Thanks for the help
[admin@MikroTik] > /export
feb/20/2021 21:45:16 by RouterOS 6.48.1
software id = U07L-4D89
model = RB760iGS
serial number = E1F20D0999FB
add admin-mac=08:55:31:64:45:6A auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.50.2-192.168.50.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.50.1/24 comment=defconf interface=bridge network=192.168.50.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.50.2 client-id=1:4:d9:f5:c2:4d:e0 mac-address=04:D9:F5:C2:4D:E0 server=defconf
add address=192.168.50.50 mac-address=1C:FE:2B:AC:CA:60 server=defconf
add address=192.168.50.51 client-id=1:c4:d6:55:40:f4:f7 mac-address=C4:D6:55:40:F4:F7 server=defconf
add address=192.168.50.52 client-id=1:d0:52:a8:54:10:3a mac-address=D0:52:A8:54:10:3A server=defconf
add address=192.168.50.54 mac-address=C4:95:00:7F:43:95 server=defconf
add address=192.168.50.11 client-id=1:0:e0:4c:1:f:20 mac-address=00:E0:4C:01:0F:20 server=defconf
add address=192.168.50.53 client-id=1:34:af:b3:58:ee:d9 mac-address=34:AF:B3:58:EE:D9 server=defconf
add address=192.168.50.22 client-id=1:48:b0:2d:1:2f:ad mac-address=48:B0:2D:01:2F:AD server=defconf
add address=192.168.50.21 mac-address=F8:54:B8:22:D4:CA server=defconf
add address=192.168.50.20 client-id=1:ac:bc:32:67:65:62 mac-address=AC:BC:32:67:65:62 server=defconf
add address=192.168.50.12 client-id=1:7a:e2:2a:10:a7:64 mac-address=7A:E2:2A:10:A7:64 server=defconf
add address=192.168.50.23 client-id=1:48:b0:2d:4:df:3d mac-address=48:B0:2D:04:DF:3D server=defconf
add address=192.168.50.0/24 comment=defconf gateway=192.168.50.1 netmask=24
set allow-remote-requests=yes servers=192.168.50.30
/ip dns static
add address=192.168.50.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input dst-address-type=local src-address-type=local
add action=accept chain=forward dst-address=192.168.50.29 dst-port=51820 in-interface=ether1 protocol=udp
add action=accept chain=forward comment="Port forwarding for Plex
\n" dst-address=192.168.50.29 dst-port=32400 in-interface=ether1 protocol=tcp
add action=accept chain=forward comment="NGNIX Proxy firewall rule" dst-address=192.168.50.29 dst-port=443 in-interface=ether1 protocol=tcp
add action=accept chain=forward comment="NGNIX Proxy firewall rule" dst-address=192.168.50.29 dst-port=80 in-interface=ether1 protocol=tcp
add action=accept chain=forward comment="NGNIX Proxy firewall rule" dst-address=192.168.50.29 dst-port=443 in-interface=ether1 protocol=udp
add action=accept chain=forward comment="NGNIX Proxy firewall rule" dst-address=192.168.50.29 dst-port=80 in-interface=ether1 protocol=udp
add action=accept chain=forward dst-address=192.168.50.29 dst-port=5001 protocol=tcp
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat comment="NGINX Proxy Port Forwarding 80
\n" dst-port=80 in-interface=ether1 protocol=tcp to-addresses=192.168.50.29 to-ports=180
add action=dst-nat chain=dstnat comment="Port forwarding for Plex" dst-port=32400 in-interface=ether1 protocol=tcp to-addresses=192.168.50.29 to-ports=32400
add action=dst-nat chain=dstnat comment="NGINX Proxy Port Forwarding 80" dst-port=80 in-interface=ether1 protocol=udp to-addresses=192.168.50.29 to-ports=180
add action=dst-nat chain=dstnat comment="NGINX Proxy Port Forwarding 443" dst-port=443 in-interface=ether1 protocol=tcp to-addresses=192.168.50.29 to-ports=1443
add action=dst-nat chain=dstnat comment="NGINX Proxy Port Forwarding 443" dst-port=443 in-interface=ether1 protocol=udp to-addresses=192.168.50.29 to-ports=1443
add action=dst-nat chain=dstnat dst-port=5001 in-interface=ether1 protocol=tcp to-addresses=192.168.50.29 to-ports=5001
add action=dst-nat chain=dstnat dst-port=51820 in-interface=ether1 protocol=udp to-addresses=192.168.50.29 to-ports=51820
/ip service
set www port=8080
/system clock
set time-zone-name=America/Chicago
/tool mac-server
/tool mac-server mac-winbox
Two of your code segments. The first is you DST Nat rules. I am going to assume that the first one (the port 80 TCP) is really like the port 80 UDP, but got mangled in the export and paste. Assuming that is true, those rules are fine.
add action=dst-nat chain=dstnat comment="NGINX Proxy Port Forwarding 80\
However, here is your issue. Your accept rules are for the original ports (80 and 443) instead of the forward destination ports (180 and 1443).
Your other option is a generic accept anything that has been DST-NATted:
add action=accept chain=forward comment="Accept all that is DST NATed"  connection-nat-state=dstnat connection-state=new
K6ccc, i made the same config type errors as many will do coming from other routers to MT.
In most routers one makes two complete list of rules for port forwarding and firewall rules.
Not so in the MT world.
One firewall rule is required for port forwarding and the the heavy lifting is all done on the dst nat rules.
So the op only needs that last rule your provided for firewall rules.
The rest depends on correctly configured dst nat rules.
Both methods work. The one accept all DST-NATted is certainly the easy route, but I wanted him to know why his rules did not work right - in other words, he might learn something. The other part is that there are times where you have a need to either not use the one accept rule, or to not use it for certain packets. Similar reason to having some rules before the “normal” accept all established and related connections.
True dat, more so I thought is the fact that really port forwarding is just one example of what dstnat rules can do.
They can be used anywhere but I am not comfortable using them within LANs for example, not sure what I would be doing LOL
Thanks guys. This helped me with my port forwarding issues. Appreciate the discussion.
This may prove useful as well.
https://forum.mikrotik.com/viewtopic.php?t=179343
