I have a building with 5 switches (non cisco) connected to a mikrotik router . Every port on these switches belong to an apartment and I use the mikrotik router to offer them internet access .
From time to time, some users started to offer dhpc services on the network, creating me problems : clients get different ip’s by dhcp .
I read on some similar posts that I should use port isolation if the switch provides it, but unfortunately I couldn’t find this feature - they have only classic vlans .
As im new to vlan area, I started to dig and I found 2 features that a cisco switch can provide : dhcp snooping and port isolation . So I’m into changing my old switches with cisco ones .
Can someone with experience on this field tell me which solution will be more efficient or maybe if there is an alternative (and elegant) way to isolate clients using classic vlans ?
Thank you for your answers and please excuse my poor English .
from mikrotik router point of view, the bridge interface now is the new “inside isolated LAN” interface where to put dhcp and refer to for firewall rules (masquerading included)
It can become hard to maintain this setup if you often have to edit it
