Hi there.
I have some questions about my Mikrotik setup with 2 WAN ports; 1 LAN port (bridge is preferable to use any available ethernet port) and port mapping
Initial:
WAN1 IP: 70.70.70.70/24 GW 70.70.70.1
WAN2 IP: 80.80.80.80/24 GW 80.80.80.1
LAN IP: 192.168.2.254/24 NO GW
I do not need any load balancing. Also, I do not need to allow any system from LAN go to the WAN except allowed connection by port mapping
I checked the forum posts and I prepared the initial configuration:
#/system reset-configuration no-defaults=yes skip-backup=yes
:global wan1ip "70.70.70.70"
:global wan1gw "70.70.70.1"
:global wan2ip "80.80.80.80"
:global wan2gw "80.80.80.1"
:global lanIpTest "192.168.2.254"
:global lanNetworkTest "192.168.2.0"
:global lanSubnet "24"
:log info ("Initial configuration started")
/interface set "ether1" name="WAN1"
/interface set "ether2" name="WAN2"
/interface set "ether3" name="LAN"
/ip address add address=($wan1ip . "/" . $lanSubnet) interface=WAN1 comment="WAN1 IP"
/ip address add address=($wan2ip . "/" . $lanSubnet) interface=WAN2 comment="WAN2 IP"
/ip address add address=($lanIpTest . "/" . $lanSubnet) network=$lanNetworkTest interface=LAN comment="LAN IP (Test)"
# Initial firewall setup
add chain=input action=accept connection-state=established,related,untracked comment="Accept established,related,untracked"
add chain=input action=drop connection-state=invalid comment="Drop invalid"
add chain=input action=accept protocol=icmp comment="Accept ICMP"
add chain=input action=accept dst-address=127.0.0.1 comment="Accept to local loopback (for CAPsMAN)"
add chain=input action=accept protocol=tcp dst-port=8291 comment="Allow remote connection using WinBox from WAN1 and WAN2"
add chain=input action=drop in-interface=!LAN comment="Drop all not coming from LAN (OPTIONAL)"
add chain=forward action=accept ipsec-policy=in,ipsec comment="Accept in ipsec policy"
add chain=forward action=accept ipsec-policy=out,ipsec comment="Accept out ipsec policy"
add chain=forward action=fasttrack-connection connection-state=established,related comment="Fasttrack"
add chain=forward action=accept connection-state=established,related,untracked comment="Accept established,related, untracked"
add chain=forward action=drop connection-state=invalid comment="Drop invalid"
add chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=WAN1 comment="Drop all from WAN1 not DSTNATed"
add chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=WAN2 comment="Drop all from WAN2 not DSTNATed"
# Mark all connections coming into WAN1 as such, do the same for WAN2:
/ip firewall mangle
add chain=prerouting in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_connection comment="Mark WAN1 packets"
add chain=prerouting in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_connection comment="Mark WAN2 packets"
# Set routing marks for all packets in those connections that come in from the LAN and go back out to the internet:
/ip firewall mangle
add chain=prerouting in-interface=LAN connection-mark=WAN1_connection action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting in-interface=LAN connection-mark=WAN2_connection action=mark-routing new-routing-mark=to_WAN2
# Make dst-nat workable
/ip firewall mangle
add chain=forward in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_connection
add chain=forward in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_connection
# Mark ICMP going to the router itself:
/ip firewall mangle
add chain=output connection-mark=WAN1_connection action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_connection action=mark-routing new-routing-mark=to_WAN2
#the NAT rules
add chain=srcnat out-interface=WAN1 action=masquerade comment="NAT Masquerade WAN1"
add chain=srcnat out-interface=WAN2 action=masquerade comment="NAT Masquerade WAN2"
add chain=dstnat action=dst-nat dst-port=5902 in-interface=WAN1 to-address=192.168.2.2 to-ports=5900 protocol=tcp comment="PM WAN1:5902 -> 192.168.2.2:5900 (VNC 192.168.2.2)"
add chain=dstnat action=dst-nat dst-port=5902 in-interface=WAN2 to-address=192.168.2.2 to-ports=5900 protocol=tcp comment="PM WAN2:5902 -> 192.168.2.2:5900 (VNC 192.168.2.2)"
# Install routers that fire for those routing marks to make sure the packets go back out the right pipe:
add dst-address=0.0.0.0/0 routing-mark=to_WAN1 gateway=$wan1gw
add dst-address=0.0.0.0/0 routing-mark=to_WAN2 gateway=$wan2gw
# Prefer WAN1 over WAN2 for all traffic except the stuff we're specifically marking to go back out WAN2
add dst-address=0.0.0.0/0 gateway=$wan1gw distance=1
add dst-address=0.0.0.0/0 gateway=$wan2gw distance=2
# Disable uneccessary services
/ip service disable www,api,ftp,telnet
/ip upnp set enabled=no
# Allow to communicate with other Mikrotik routers and MAC discovering from the LAN only
/ip neighbor discovery-settings set discover-interface-list=all
/tool mac-server set allowed-interface-list=all
/tool mac-server mac-winbox set allowed-interface-list=all
# Set default SSH port 3000
/ip service set ssh port=3000
:log info ("Initial configuration completed")
I’m trying to test it with just one PC with IP 192.168.2.2 with no GW defined
The rest of the systems in 192.168.2.0/24 have 192.168.2.2 as the default gateway
Could you please help me with several questions:
- Port mapping to 192.168.2.2:5900 does not work unless I define 192.168.2.254 (router IP) in 192.168.2.2 system as a default gateway. Is it possible to avoid that? I probably missed one of the needed routes.
- I need to prepare two scripts with two different LAN IP subnets and rules. What is the correct way to prepare one merged scrit that can handle both LAN subnets at the same time?
Like I need thandle 192.168.2.0/24 (port mapping WAN:5900 → 192.168.2.1:5900 and WAN:5920 → 192.168.3.1:5900) - I need to allow access SMB share from WAN to 192.168.2.1. Will mapped ports TCP/UDP 139 and TCP 445 be enough to use SMBv3? I need to access 192.168.2.1\Shared_folder as WAN1_IP\Shared_folder and WAN2_IP\Shared_folder.
- I need to prevent any other network connections from LAN to WAN1/WAN2. (i think it is done)
I have another script I made before that seems to be work OK except I can’t use SMB share access, but I can use VNC, two LAN subnets, and I have no default GW set in 192.168.2.2
I believe it has a problem with packet routing from LAN to WAN1/WAN2
:global wan1ip "80.80.80.1"
:global wan2ip "70.70.70.1"
:global lanIp1 "192.168.2.254"
:global lanNetwork1 "192.168.2.0"
:global lanIp2"192.168.3.254"
:global lanNetwork2 "192.168.3.0"
# Bridge setup
/interface bridge add name=bridge disabled=no auto-mac=yes protocol-mode=rstp comment="LAN bridge"
/interface bridge port add interface=ether3 bridge=bridge comment="Connect ether3 to bridge"
/interface bridge port add interface=ether4 bridge=bridge comment="Connect ether4 to bridge"
/interface bridge port add interface=ether5 bridge=bridge comment="Connect ether5 to bridge"
/ip address add address=($lanIp1 . "/" . $lanSubnet) network=$lanNetwork1 interface=bridge comment="bridge IP LAN1"
/ip address add address=($lanIp2 . "/" . $lanSubnet) network=$lanNetwork2 interface=bridge comment="bridge IP LAN2"
/interface list add name=WAN1 comment="WAN1"
/interface list add name=WAN2 comment="WAN2"
/interface list add name=LAN comment="LAN"
/interface list member add list=LAN interface=bridge comment="LAN -> bridge"
/interface list member add list=WAN1 interface=ether1 comment="WAN1 -> ether1"
/interface list member add list=WAN2 interface=ether2 comment="WAN2 -> ether2"
/ip address add address=($wan1ip . "/" . $lanSubnet) interface=ether1 comment="WAN1 GW"
/ip address add address=($wan2ip . "/" . $lanSubnet) interface=ether2 comment="WAN2 GW"
# User administration
add chain=input action=drop in-interface-list=!LAN comment="Drop all not coming from LAN (OPTIONAL)"
add chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN1 comment="Drop all from WAN1 not DSTNATed"
add chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN2 comment="Drop all from WAN2 not DSTNATed"
/ip firewall mangle
add chain=prerouting in-interface-list=WAN1 action=mark-connection new-connection-mark=WAN1_connection comment="Mark WAN1 packets"
add chain=prerouting in-interface-list=WAN2 action=mark-connection new-connection-mark=WAN2_connection comment="Mark WAN2 packets"
/ip firewall mangle
/ip firewall mangle
add chain=prerouting in-interface-list=LAN connection-mark=WAN1_connection action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting in-interface-list=LAN connection-mark=WAN2_connection action=mark-routing new-routing-mark=to_WAN2
/ip firewall mangle
add chain=forward in-interface-list=WAN1 action=mark-connection new-connection-mark=WAN1_connection
add chain=forward in-interface-list=WAN2 action=mark-connection new-connection-mark=WAN2_connection
#the NAT rules
add chain=srcnat out-interface=bridge action=masquerade comment="NAT Masquerade WAN1"
add chain=srcnat out-interface=bridge action=masquerade comment="NAT Masquerade WAN2"
add chain=dstnat action=dst-nat dst-port=20 to-address=192.168.2.1 to-ports=20 protocol=tcp comment="PM WAN:20 -> 192.168.2.1:20 (FTP)"
add chain=dstnat action=dst-nat dst-port=21 to-address=192.168.2.1 to-ports=21 protocol=tcp comment="PM WAN:21 -> 192.168.2.1:21 (FTP)"
add chain=dstnat action=dst-nat dst-port=23 to-address=192.168.2.1 to-ports=23 protocol=tcp comment="PM WAN:23 -> 192.168.2.1:23 (Telnet)"
add chain=dstnat action=dst-nat dst-port=5900 to-address=192.168.2.2 to-ports=5900 protocol=tcp comment="PM WAN:5900 -> 192.168.2.2:5900 (VNC 192.168.2.2)"
add chain=dstnat action=dst-nat dst-port=5920 to-address=192.168.3.1 to-ports=5900 protocol=tcp comment="PM WAN:5920 -> 192.168.3.1:5900 (VNC 192.168.3.11)"
add dst-address=0.0.0.0/0 routing-mark=to_WAN1 gateway=$wan1ip
add dst-address=0.0.0.0/0 routing-mark=to_WAN2 gateway=$wan2ip
add dst-address=0.0.0.0/0 gateway=$wan1ip distance=1
add dst-address=0.0.0.0/0 gateway=$wan2ip distance=2
The main difference are:
- I have no in-interface defined in dst-nat (and one rule instead of 2 WAN1/WAN2)
- I’m using interface lists
- 80.80.80.1 and 70.70.70.1 are both mikrotik IPs and i used these values in routes.
Please advise, how I need to change Script #1 to achieve my goals.
Thank you!
