I’m new to RouterOS and MikroTik in general and I experienced something strange. I poked around on the forum and found this topic which is similar, but not quite the same:
Using 6.7 and adding non-duplicate addresses into an Address List through WebFig, my RB2011 is no longer remotely accessible, either by ping, SSH, or HTTP. When I was adding the addresses, I noticed that the port on the upstream switch that connects to the RB2011 went down, then came back up. Ever since then, I am unable to access the router. I thought perhaps the configuration was lost, but it’s still there, as the RB2011 responds to ARP requests on the non-default IP addresses configured on it. The firewall configuration itself was a default config with the default rules installed - I was merely creating an address list so I could begin configuring the firewall.
I have been unable to reboot the RB2011 because I’m accessing it remotely and don’t have local access until Monday. If a manual reboot does not let me gain access, is there any recourse I have so I can keep the existing configuration? Or would a manual configuration reset be my only option? While I don’t think the above reported bug is exactly the same, there’s always possibility that I clicked ‘submit’ twice in rapid succession while adding the last address to the list, I don’t know.
Sorry to respond to my own post, but a manual reboot did work and let me back in the router. That said, does this sound like the previously reported bug or perhaps something new?
Hi i have the same problem.
I’m running version 6.7 on a 2011UiAS-2HnD.
When i add a new item or change the name of a list on the adres list under “Firewall → Adress Lists” the router blocks all communication.
This happened to me first when i was connected from the WAN side, but happend to me again when connected on the LAN side.
Rebooting the router solves this issue, but this is a bug which should be solved.
i was working on a firewallscript which adds certain ipadresses on a blocked list, but i rather not implement this now because it might cause a crash on the router.
