PowerBox Plastic Zip Tie Outdoor / UV Rated?
Are the white zip ties that come with the PowerBox UV stabilized or appropriately rated for outdoor use?
Or, are these zip ties for indoor use only?
Thank you - Chris
Please use stainless steel hose clamp for product fastening to antenna pole. Zip ties are intended for cable management purposes
