We recieved a new batch of powerbox Pro’s this week. When I setup the one it reports that its a Hex POE and not Powerbox Pro, though the model number is 960PGS. The big issue is that it is not providing POE out, nor is it giving me the POE menu tab in windbox interface menu.
Do I have a dud powerbox or wrong factory config on the board?
Another one in the order I received gave the same issue, so thats 2 in a batch of 4. Spoke to my supplier and I can return it for a replacement under warranty confirmed by Mikrotik. I think there was a batch of bad powerbox Pro’s that came out. I have decided to keep them though as use them as regular 5 port RB’s, its cheaper than shipping back to my supplier and getting the replacements and ordering regular 750G’s or similar.
On a side note, I also received a MantBoxPro19 that does not power up via POE, straight out the box. That I have to to return though as its useless to me without POE, though a different supplier.
I pulled two of the Mikrotik PowerBox Pro units from my inventory ( still in the un-opened boxes ). Non of the ethernet interfaces have any POE-out setting ( POE does not show up in the Winbox menu on the ethernet ).
Grrrrrr … #!fkit-!!!
QA inspection and testing on these products prior to shipping from Mikrotik appears to be lacking or non-existent.
Just thinking: is this RouterOS/firmware related ??? The PowerboxPro identifying as hEX PoE appeared from a certain RouterOS version onward AFAIK.
Powerbox Pro’s here are OK. Running RoS 6.45.6, but announcing as “hEX PoE (mipsbe)”.also. WinBox used is v3.24. PoE tab on ethernet interfaces except ether1.
FYI only.
Sad news, I have two units on my network working fine (except I can’t see now on Winbox voltage and temperature, on CLI is working fine). I’m running 6.48.
