PowerBox (Pro) power supply options.
I have several PowerBox and PowerBox Pro units used as a PoE supplies in bridge mode.
Some are connected to POE (in) on port Eth0 and the same time to DC (in) on the electric jack.
Which one of the power option is primary?
Or is it taking the one with higher or lower voltage or is it sharing both the same time?
What is the logistic behind it and is there something I can control which one is used when both are plugged and supplying power?
Is there an option to see total power consumption of the unit taken from POE (in) or power jack?
BTW PowerBox is a great option for dual power supplies in remote locations.
