Hi everyone ,
I am not an experienced programmer but i love Mikrotik and Powershell , so here is my simple mikrotik powershell cmdlet module
i hope you like it , Please let me know if you think we can improve it
it supports API and API-SSL , for more information about Filters and Attributes please check http://wiki.mikrotik.com/wiki/Manual:API
Thank you
Exmaples:
PS C:>Import-Module Mikrotik.dll
PS C:> Get-Command -Module Mikrotik
CommandType Name Version Source
Cmdlet Connect-Mikrotik 1.0.0.0 Mikrotik
Cmdlet Disconnect-Mikrotik 1.0.0.0 Mikrotik
Cmdlet Send-Mikrotik 1.0.0.0 Mikrotik
#Connecting using API default port and save the connection object in C$ then we can use C$ to send commands
PS C:> $C=Connect-Mikrotik -IPaddress 192.168.3.1 -UserName admin -Password password
Connected to 192.168.3.1 , Identity=TEST1
#Connecting using API-SSL default port
PS C:> $C=Connect-Mikrotik -IPaddress 192.168.3.1 -UserName admin -Password password -UseSSL
#Connecting using API-SSL on diffrenet port that 8729
PS C:> $C=Connect-Mikrotik -IPaddress 192.168.3.1 -UserName admin -Password svgafara -UseSSL -Port 3323
#get all ethernet interface which is not disabled
PS C:> Send-Mikrotik -Connection $C -Command â/interface/getallâ -Filters âtype=etherâ,âdisabled=falseâ
#add ip to ether 1
PS C:> Send-Mikrotik -Connection $C -Command â/ip/address/addâ -Attributes âinterface=ether1â,âaddress=192.168.201.1/24â
#get ether1 ip addres
PS C:> Send-Mikrotik -Connection $C -Command â/ip/address/getallâ -Filters âinterface=ether1â
#Close the connection
PS C:> Disconnect-Mikrotik -Connection $C
Mikrotik-PS-CMDLET-SRC.zip (29.6 KB)
Mikrotik-PS-Module.zip (5.39 KB)
