Made a typo in title PCC script modification
http://wiki.mikrotik.com/wiki/PCC
my multiple gateways reside all on the same ip range ie.. 192.168.1.20 and 192.168.1.21 etc…
the remote remote routers access the individual gateways assigned in routes on each router and only use one interface wlan1
my question is can i use the ppc script to loadbalance since the remote router uses only 1 interface.
and if so please give an example of the change to the script needed.
thanks
PS.. for what its worth I tried to hire a consultant to answer this about two months ago and I guess he is either dumber than a box of rocks or just has too much money which in the latter case he should take his name off the consulting list and just show off giving little simple talks at Mikrotik MUM’s
