PPP on a specific Wan connection
Hello everyone,
On a remote mikrotik i have a PPPoE on eth1 interface, and another WAN on eth2.
To manage this Mikrotik i’ve created an L2TP tunnel to my Mikrotik Routerboard. So i’ve an L2TP client pointing to hostname of my public IP.
How can i configure it so that this L2TP comes out on wan1 or wan2? Using mangle or how?
Thanks people
There are different ways. If the server has static public address, then the easiest is probably to add route to this address via gateway of either wan1 or wan2.
Thank you!
it’s simpler than I thought. i Will try this way.
i have a new difficulty.
Another vpn connect to this mikrotik, but it has no static IP, how can i route it back on the wan i want?
Someone can help me?
Everything you need should be in this post. The last paragraph explains its relationship to your case.
