PPPoE Client inside PPPoE Server
Hi there,
I’ve set up a simple PPPoE server with a local PPP user on an RB951Ui-2HnD (RouterOS 6.27).
I’ve created a PPPoE client interface (using with the local PPP user) on the same RB951Ui-2HnD.
My problem is tat the session never becomes active… What is my error?
if you write your config maybe we can help
Here is my config:
add name=bridge-PPP
add bridge=bridge-PPP interface=ether2
add name=pool-ppp ranges=172.16.6.2-172.16.6.100
/ppp profile
add bridge=bridge-PPP change-tcp-mss=yes local-address=172.16.6.254 name=\
    profilePPP remote-address=pool-ppp use-encryption=yes
/ppp secret
add name=user password=pwd profile=profilePPP service=pppoe
/interface pppoe-client
add add-default-route=yes allow=pap,chap disabled=no interface=ether2 mrru=\
    1600 name=pppoe-out1 password=pwd profile=profilePPP use-peer-dns=yes \
    user=user
/interface pppoe-server server
add authentication=pap,chap default-profile=profilePPP disabled=no interface=\
    bridge-PPP one-session-per-host=yes service-name=ADSL
log says:
pppoe-out1: initializing...
pppoe-out: connecting...
pppoe-out1 terminating... - disconnected
What’s my fault?
Dear planetcaravan
what is your scenario ?
we need more details about your pppoe user and the interface connected to it
also about you local pppoe server and the interface that its used .
Thanks for your answer. This PPPoE is connected to the internet via ether1 and I want to set a PPPoE client on the same RB in order to create a LAN network on the other ethernet interfaces of the RB.
Very confused about what you are trying to do. You have ether2 in a bridge, and a pppoe-server running on the bridge, but then you also have a pppoe-client on ether2. That is nonsense. Once ether2 is in a bridge, you should not reference it or treat it as a discrete interface. You should only ever reference the bridge interface.
And it makes no sense to have a pppoe-client and a pppoe-server on the same interface unless you want your client to connect to another pppoe-server that is running elsewhere on the same ethernet broadcast domain. Are you trying to make the pppoe-client on your router connect to itself (to the server that the same router is running)?? You can’t do that, and furthermore, I can’t conceive of a scenario in which anybody would want to do that or find such a configuration useful.
– Nathan
I think you must bridge all interfaces except ether1
then create your pppoe server for that bridge
your local pppoe users must connected from ether2 to ether5
try this and feed back if its work :
add name=pool1 ranges=172.16.6.2-172.16.6.100
add mtu=1500 name=bridge1
/ppp profile
add change-tcp-mss=yes local-address=1.1.1.1 name=PPPoE_Local only-one=yes remote-address=pool1 use-compression=no use-encryption=no use-ipv6=no use-mpls=no use-vj-compression=no
add authentication=pap,chap default-profile=PPPoE_Local disabled=no interface=bridge1 max-mru=1480 max-mtu=1480 mrru=1600 service-name=service1
add action=masquerade chain=srcnat src-address=172.16.6.2-172.16.6.100
Don’t forget to add your users in secrets
