Hello All,
I’ve encountered a problem and I’m not sure whether it is down to a bad configuration on my part or perhaps a bug:
As things presently stand, I have a CRS328-24P-4S+RM Cloud Router Switch (CRS) with a “main” connection going into port 24. On this connection there are 3 VLANs: One is for general broadband access (PPPoE logins), the second is for a private management network and the third is another private customer network. A VLAN interface has been set up for each of these VLANs on port 24. The two private network VLAN interfaces are then assigned to a separate bridge each (bridge 1 and bridge 2 for example) and various ports on the CRS are mapped to either bridge 1 or 2. I also have a PPPoE client running on the CRS which authenticates through the broadband access VLAN interface and provides connectivity to a third bridge (bridge 3) on the CRS, offering internet connectivity to our office and again, various ports on the CRS are mapped onto this bridge.
Everything has been working absolutely fine and exactly as expected until a new client moved into our building. They wanted connectivity from us and so we installed a cable through to their room. Their own router will need to login via PPPoE and so my plan was to create a fourth bridge (bridge 4) and assign the broadband access VLAN to this bridge, tell our PPPoE client on the CRS to authenticate via this bridge and then map one of the spare ports on the CRS to the new bridge so that our client can also login via bridge 4. As soon as I did this, the CRS PPPoE client would disconnect with an authentication failure, connect for a split second and then fail again in a repeating cycle. The new customer connection worked flawlessly from the minute I created the new bridge and their router logged in with PPPoE no problem at all. After various attempts at enabling and disabling bridges and interfaces, the CRS PPPoE client connected fine on bridge 4 and worked all through the night as did the new customer’s connection. However, come this morning and I find that everything had gone to pot! The CRS kept crashing and needed a reboot and the only way I could make things stable again was to revert my changes and have the CRS PPPoE client connect directly via the broadband access VLAN interface. This of course means that our new client is without connectivity once again.
Can anybody recommend a configuration scenario that would allow our CRS to connect using PPPoE over the broadband access VLAN and enable me to assign the same VLAN to a port on the CRS such that the new client’s router can also login with PPPoE? My sincere apologies if I have not explained things very well.
I really hope someone can come forward with a solution and I shall eagerly await your replies / suggestions.
With best wishes,
Paul.
