Hey guys,
If you encounter the following problems:
a. When PPPoE dial-up, the MTU will auto adjust from 1492 to 1480 after connected 3 seconds.
b.If you enable IPv6 you will get many warnings in the log similar to:
invalid mtu 1492 on pppoe-out1 from fe80::200:5eff:fe00:101
invalid mtu 1492 on pppoe-out1 from fe80::200:5eff:fe00:102
invalid mtu 1492 on pppoe-out1 from fe80::200:5eff:fe00:103
invalid mtu 1492 on pppoe-out1 from fe80::200:5eff:fe00:104
invalid mtu 1492 on pppoe-out1 from fe80::200:5eff:fe00:105
invalid mtu 1492 on pppoe-out1 from fe80::200:5eff:fe00:106
Then congratulations, this is because your ISP uses Huawei’s Broadband Remote Access Server and you are a victim of Huawei equipment.
Affected peer equipment models: ME60, NE40, NE9000, VNE9000, etc.
Here is an explanation of the this issue:
a.Huawei has launched the vBRAS structure, which splits the traditional BRAS into the User Plane and the Control Plane.
b.The Control Plane name is VNE9000, which is an X86 virtual machine deployed on the ISP’s cloud.
c.The User Plane consists of an X86 virtual machine or or an ARM physical machine or a traditional BRAS (such as ME60, NE40, etc.), there are deployed at sites near subscribers.
d.The User Plane is incorporated into the control plane and managed using OpenFlow.
e.The User Plane and Control Plane are connected using VXLAN, they may be hundreds of kilometers apart, with a delay of about 2 to 8 ms
f.Subscriber’s PPPoE dial-up request will first reach the User Plane. If it is a packet of 0x8863 or 0x8864, the subscriber information will be injected and forwarded to the Control Plane through VXLAN. Then, after the Control Plane completes PPP authentication, it will send the flow table to the User Plane through OpenFlow. If it’s a normal PPPoE Session packet, it will be fast forward on the user plane.
g.RouterOS and most network equipment implement PPPoE in compliance with RFC4638.
h.Therefore, when the RouterOS’s PPPoE Client dial-up, if you set the MTU>1488, it will send an Echo Request packet with a length equal to the MTU to the other end during the LCP negotiation phase.
i.Yes, you have found the issue now. The size of your Echo Request packet has exceeded the VXLAN MTU between the User Plane and the Control Plane. At this time, the Control Plane will never receive your Echo Request or reply to your Echo Request. Therefore, when your PPPoE Client fails to get an Echo Reply after three attempts, it adjusts its MTU to 1480 in disappointment.
What my friends did:
a. Contacted the ISP and they replied that it was a problem with the user’s equipment.
b. Contacted Huawei, they believe they are not at fault and therefore will not fix the problem.
c. Contacted another ISP and they replaced ZTE’s BRAS for my friend.
You may ask, have some suggest about this?
q. You can wait for RouterOS to launch an option that allows you to disable the RFC4638 test.
b. You can contact your ISP to replace the BRAS of other vendor for you. Such as ZTE, NOKIA, H3C, Juniper, they all have no problems.
c. You can complain to the ISP investigate this problem and ask the vendor to fix it.
d. You can adjust the maximum MTU to 1488 if you can accept it (RouterOS will not send RFC4638 test packets when MTU <= 1488).
Best wishes.
