PPPoE deny users modify other user stations
Is there a firewall that can prevent users to reach other user’s nanostations to modify settings since most nano’s are ubnt for user/pass?
In the network, each user will get an ip starting from 192.168.10.1 and continue to 192.168.10.250
so user 192.168.10.40 can easily reach 192.168.10.41 or any other ip in the range.
i need a firewall that can drop the connection
Thanks in advance
Hello
Please send your network diagram…
One router one subnet. Every user will get 192.168.10.0/24
thanks,
if your client and their Radios are in the same broadcast domain your mikrotik can not help you…
wouldn’t this solve the problem?
 chain=forward action=drop protocol=tcp dst-port=80 src-address=192.168.10.0/24 dst-address=192.168.10.0/24
Hi
no that rule in not work for your problem.
/ip firewall can be used for layer3 filtering but you say to me that your users in the same broadcast domain.
all user stations are ubiquiti devices
