hi
i have ccr1036-12g-4s and the same problem
i have 1500 pppoe online user and when my online user is about 1300 the same problem happend
and other user cant connect
what am i do ?
hello
thanks
if i upgrade to 6.8rc1 and configration again better or 6.7 ???
6.8rc1 used multi core processor for ppp and have high
speed for users but conflict by my acconting server .
after 10 min uptime all users logout from accounting and stay connect
in router …
*) ospf - fixed checksum calculation for OSPFv3 AS-external-LSAs;
*) default configuration - changed dhcp server lease time to 10 minutes;
*) fixed port isolation on CRSs (bug introduced in v6.6);
*) smb - added support for SMB 2.002
*) timezone information updated;
*) ppp - fixed ppp bridging (did not work since v6.6);
*) improved speed of PPP, PPPoE, PPTP & L2TP on multicore routers;
*) address-list - fix crash when adding two identical address list entries (not allowed any more);
*) fixed multicast forwarding on CCRs;
I intend to buy a CCR 1016 router in order to manage over 500 PPP clients with bandwidths between 2 and 10 Mb/s.
As I have seen here,this type of router is full of bugs and it can be a problem.
What do you recomend? It can handle this job or not? The last OS versions resolve this problems?
Now I am using a HP ProLiant server with CentOS linux to do this job. It have over 2 years of non stop working without any problems.
I want to change it be couse it has 450 W instant power consumption… But I don’t want a piece of equipements with bugs…
So, what do you recommend?
