Hi, i have a mikrotik setup using dual wan. I have setup PPPoE and i want to control each client base on IP on which ISP they will use. I want half of the PPPoE will go to ISP1 and the other half will go ISP2.
MikroTik RouterOS 7.20 (c) 1999-2025 https://www.mikrotik.com/
add name=bridge-PPPoE
add name=bridge-lan
set [ find default-name=ether1 ] name=ISP1-ETH1
set [ find default-name=ether2 ] name=ISP2-ETH2
set [ find default-name=ether3 ] name=LAN-ETH3
set [ find default-name=ether5 ] name=PPPoE-ETH5
add name=WAN-LIST
add name=pool-LAN ranges=192.168.0.10-192.168.0.254
add name=pool-pppoe ranges=192.168.2.10-192.168.2.254
add name=dhcp_pool2 ranges=192.168.0.2-192.168.0.254
add name=dhcp_pool3 ranges=192.168.2.2-192.168.2.254
add address-pool=dhcp_pool2 interface=bridge-lan lease-time=1d30m name=dhcp1
add address-pool=dhcp_pool3 interface=bridge-PPPoE lease-time=1d30m name=dhcp2
/ppp profile
add local-address=192.168.2.1 name=PowerHouse rate-limit=15M/15M remote-address=pool-pppoe
/queue type
add kind=fq-codel name=FQ-CODEL
/queue simple
add max-limit=15M/50M name=FQ-CODEL priority=4/4 queue=FQ-CODEL/FQ-CODEL target=bridge-lan
/queue tree
add limit-at=150M max-limit=150M name=DownTotal parent=global priority=1 queue=pcq-download-default
add limit-at=25M max-limit=25M name=UpTotal parent=global priority=1 queue=pcq-upload-default
add max-limit=150M name=ICMP_Down packet-mark=ICMP_Down parent=DownTotal priority=1 queue=default
add max-limit=25M name=ICMP_Up packet-mark=ICMP_Up parent=UpTotal priority=1 queue=default
add max-limit=100M name=DNS_Down packet-mark=DNS_Down parent=DownTotal priority=2 queue=default
add max-limit=25M name=DNS_Up packet-mark=DNS_Up parent=UpTotal priority=2 queue=default
add limit-at=150M max-limit=150M name=Web_Down packet-mark=Web_Down parent=DownTotal priority=3 queue=default
add max-limit=25M name=Web_Up packet-mark=Web_Up parent=UpTotal priority=3 queue=default
/routing table
add disabled=no fib name=to_ISP1
add disabled=no fib name=to_ISP2
add bridge=bridge-lan interface=LAN-ETH3
add bridge=bridge-PPPoE interface=PPPoE-ETH5
add interface=ISP1-ETH1 list=WAN-LIST
add interface=ISP2-ETH2 list=WAN-LIST
/interface pppoe-server serverService is on a slave interface
add disabled=no interface=PPPoE-ETH5 service-name=PowerHouse1
add address=192.168.0.1/24 interface=bridge-lan network=192.168.0.0
add address=192.168.2.1/24 interface=bridge-PPPoE network=192.168.2.0
/ip dhcp-client
add add-default-route=no interface=ISP1-ETH1 use-peer-dns=no use-peer-ntp=no
add add-default-route=no interface=ISP2-ETH2 use-peer-dns=no use-peer-ntp=no
add address=192.168.0.0/24 gateway=192.168.0.1 netmask=24
add address=192.168.2.0/24 gateway=192.168.2.1 netmask=24
set servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=192.168.1.0/24 list=Wan_List
add address=192.168.254.0/24 list=Wan_List
add address=192.168.0.0/24 list=Lan_List
add address=192.168.2.0/24 list=PPPoE_List
add action=drop chain=output disabled=yes dst-address=8.8.8.8
/ip firewall mangle
add action=accept chain=prerouting comment="No Balance Traffic traffic entry on LAN" dst-address-list=Lan_List src-address-list=Lan_List
add action=accept chain=prerouting comment="Access to ISP Routers" dst-address-list=Wan_List
add action=mark-connection chain=input comment=Input in-interface=ISP1-ETH1 new-connection-mark=ISP1_Conn
add action=mark-connection chain=input in-interface=ISP2-ETH2 new-connection-mark=ISP2_Conn
add action=mark-connection chain=prerouting comment="Connection Mark for ISP1" connection-mark=no-mark in-interface=ISP1-ETH1 new-connection-mark=ISP1_Conn
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ISP2-ETH2 new-connection-mark=ISP2_Conn
add action=mark-routing chain=output comment=Output connection-mark=ISP1_Conn new-routing-mark=to_ISP1 passthrough=no
add action=mark-routing chain=output connection-mark=ISP2_Conn new-routing-mark=to_ISP2 passthrough=no
add action=mark-connection chain=prerouting comment=Pcc connection-mark=no-mark dst-address-type=!local in-interface=bridge-lan new-connection-mark=ISP1_Conn
per-connection-classifier=both-addresses-and-ports:2/0
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=bridge-lan new-connection-mark=ISP2_Conn
per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting comment="Routing Mark" connection-mark=ISP1_Conn in-interface=bridge-lan new-routing-mark=to_ISP1 passthrough=no
add action=mark-routing chain=prerouting connection-mark=ISP2_Conn in-interface=bridge-lan new-routing-mark=to_ISP2 passthrough=no
add action=mark-connection chain=prerouting comment=QOS-ICMP new-connection-mark=ICMP_Con protocol=icmp
add action=mark-packet chain=prerouting connection-mark=ICMP_Con in-interface=bridge-lan new-packet-mark=ICMP_Up passthrough=no
add action=mark-packet chain=prerouting connection-mark=ICMP_Con in-interface=ISP1-ETH1 new-packet-mark=ICMP_Down passthrough=no
add action=mark-packet chain=prerouting connection-mark=ICMP_Con in-interface=ISP2-ETH2 new-packet-mark=ICMP_Down passthrough=no
add action=mark-connection chain=prerouting comment="WEB(Http + Https)" dst-port=80,443 new-connection-mark=Web_Conn protocol=tcp
add action=mark-connection chain=prerouting dst-port=80,443 new-connection-mark=Web_Conn protocol=udp
add action=mark-packet chain=prerouting connection-mark=Web_Conn in-interface=bridge-lan new-packet-mark=Web_Up passthrough=no
add action=mark-packet chain=prerouting connection-mark=Web_Conn in-interface-list=WAN-LIST new-packet-mark=Web_Down passthrough=no
add action=mark-connection chain=prerouting comment=DNS dst-port=53 new-connection-mark=DNS_Conn protocol=tcp
add action=mark-connection chain=prerouting dst-port=53 new-connection-mark=DNS_Conn protocol=udp
add action=mark-packet chain=prerouting connection-mark=DNS_Conn in-interface=bridge-lan new-packet-mark=DNS_Up passthrough=no
add action=mark-packet chain=prerouting connection-mark=DNS_Conn in-interface-list=WAN-LIST new-packet-mark=DNS_Down passthrough=no
add action=masquerade chain=srcnat out-interface=ISP1-ETH1
add action=masquerade chain=srcnat out-interface=ISP2-ETH2
add check-gateway=ping comment="Recursive Route ISP1" disabled=no dst-address=8.8.8.8/32 gateway=192.168.1.1 routing-table=main scope=10 suppress-hw-offload=no
target-scope=10
add comment="Recursive Route ISP2" disabled=no distance=1 dst-address=1.0.0.1/32 gateway=192.168.254.254 routing-table=main scope=10 suppress-hw-offload=no
target-scope=10
add check-gateway=ping comment="Main Route ISP1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=8.8.8.8 routing-table=main scope=30 suppress-hw-offload=no
target-scope=11
add check-gateway=ping comment="Main Route Isp2" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=1.0.0.1 routing-table=main scope=30 suppress-hw-offload=no
target-scope=11
add check-gateway=ping comment="Route to ISP1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=8.8.8.8 routing-table=to_ISP1 suppress-hw-offload=no
target-scope=11
add check-gateway=ping comment="Back Up Route ISP1" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=1.0.0.1 routing-table=to_ISP1 suppress-hw-offload=no
target-scope=11
add check-gateway=ping comment="Route to ISP2" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=1.0.0.1 routing-table=to_ISP2 suppress-hw-offload=no
target-scope=11
add check-gateway=ping comment="Backp Up Route ISP2" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=8.8.8.8 routing-table=to_ISP2 suppress-hw-offload=no
target-scope=11
/ppp aaa
set enable-ipv6-accounting=yes use-radius=yes
/ppp secret
add name=pppoe1 profile=PowerHouse
add name=pppoe2 profile=PowerHouse
add name=pppoe3 profile=PowerHouse
