PPPPoE Bridge, 2 VLAN.
Hello guys, I've been searching wide and far, no avail.
I hope you can help me.
I have no experience with mikrotik, we had Cisco on college and the whole concecpt of GUI is new to me. I've been playing around a little.
I have two 951, one of which is my "main", who controls DHCP and NAT/masqerade on out.int. PPPoE and 1 mAP.
I want to have two separate WLAN's, one for guest and one for staff. (virtual ap on the main wlan1).
I have played around with VLAN but no go.
My export:
add name=bridge1
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether3 ] name=ether3-Soba
set [ find default-name=ether4 ] name=ether4-Rig
set [ find default-name=ether5 ] name=ether5-951A3
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-WAN max-mru=1480 max-mtu=1480 mrru=1600 name=pppoe-out1 user=*******@htnet-dsl
/ip neighbor discovery
set ether1-WAN discover=no
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=Klapa10 supplicant-identity=""
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=apartmaniricov supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=ap-bridge name=Klapa10 security-profile=Klapa10 ssid=Klapa10
add name=dhcp_pool1 ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=dhcp1
add bridge=bridge1 interface=ether3-Soba
add bridge=bridge1 interface=ether4-Rig
add bridge=bridge1 interface=ether5-951A3
add bridge=bridge1 interface=Klapa10
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-server alert
add disabled=no interface=ether1-WAN
add address=192.168.1.0/24 dns-server=8.8.8.8 gateway=192.168.1.1
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=dst-nat chain=dstnat dst-port=60003 protocol=tcp to-addresses=192.168.1.6 to-ports=***
add action=dst-nat chain=dstnat dst-port=60004 protocol=tcp to-addresses=192.168.1.7 to-ports=***
no interface
add action=masquerade chain=srcnat out-interface=*1D
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/queue simple
add disabled=yes max-limit=512k/1M name=queue1 target=*14
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name=Bridge
/system leds
set 5 interface=Klapa10
/system routerboard settings
set protected-routerboot=disabled
/system scheduler
add interval=5m name=no-ip_ddns_update on-event=no-ip_ddns_update policy=read,write,test start-date=feb/07/2018 start-time=00:00:00
If you have a solution here on the forums, with similar setup, much appreciated.
Thank you, and sorry for wasting your precious time :slight_smile:
https://wiki.mikrotik.com/wiki/Manual:VLANs_on_Wireless
