ROS 3.23, RB433
I’m trying to create a pptp tunnel which is originated from this router and terminates
on another ROS 3.23 across the Internet.
I have done this successfully many times with what I believe is the same configuration. When I enable the pptp client, the log file (on the client side) shows the following:
20:13:17 pptp,ppp,info pptp-out1: terminating… - could not create interface
Here is my pptp client configuration:
] /interface pptp-client> print detail
0 X name="pptp-out1" max-mtu=1460 max-mru=1460 mrru=disabled
connect-to=vv.xx.yy.zz user="admin" password="mypassword"
profile=default-encryption add-default-route=no dial-on-demand=no
allow=pap,chap,mschap1,mschap2
As I said, this works fine when originated from my other Mikrotik nodes, some of which are running 3.23.
Any ideas of where to look for problems? I’ve never seen this error in the log before.
