PPTP Client says "authenticated" but never connects
I’m attempting to configure my Routerboard at home as a pptp client for a Windows Server at my company. I can set up this VPN properly in my Ubuntu (network-manager) but RouterOS fails to achieve that. When I enable the pptp client I get the following:
02:14:46 pptp,ppp,info pptp-out1: initializing...
02:14:46 pptp,ppp,info pptp-out1: dialing...
02:14:46 pptp,ppp,info pptp-out1: authenticated
02:14:49 pptp,ppp,info pptp-out1: terminating...
02:14:49 pptp,ppp,info pptp-out1: disconnected
02:14:49 pptp,ppp,info pptp-out1: initializing...
02:14:49 pptp,ppp,info pptp-out1: dialing...
02:14:52 pptp,ppp,info pptp-out1: authenticated
02:14:52 pptp,ppp,info pptp-out1: terminating...
02:14:52 pptp,ppp,info pptp-out1: disconnected
And this goes on in a infinite loop. Please note this is not a routing issue. The PPTP session itself is never stabilished. What puzzles me is even if I set a fake login and fake password, the log still outputs the “pptp-out1: authenticated” line. But this only happens if I set pptp client to connect to a real PPTP server. If I set a fake IP or to a server that is not running a PPTP server the connection fails right away as expected.
I’m using RouterOS v6.4. How can I debug it?
export you config here for me ,
are you use radius server to authenticate ?
make sure you ppp profile work good
No RADIUS envolved. Please note the PPTP server is a Windows Server. RouterOS is playing a client role here. My settings are as follows:
[admin@xpto] /ppp> export
# sep/22/2013 03:35:06 by RouterOS 6.4
# software id = NX8L-6QQ5
/ppp profile
add name=VPN
[admin@xpto] /ppp>
/interface pptp-client
add allow=mschap2 connect-to=200.200.200.200 disabled=no name=pptp-out1 password="mypassword" user=mylogin
so check the security parameters because your problem is here
authenticated
authenticated
Thanks for your reply but I still belive this is not the issue. As I mentioned before, I can ensure this VPN is functional because I can configure and connect to it using Ubuntu as a PPTP client. Regarding security, both have the same setting activated:
So both PTTP clients have only mschap2 activated. And the Ubuntu one works, the RouterOS doesn’t. Also I’d like to emphasize the “authenticated” message appears in the RouterOS log even if I use the wrong password and a non-existant login name. So this makes me belive there is something very wrong (probably a bug).
Any clue on how can I debug what is going on?
try modifying your “VPN” ppp profile to have “Change TCP MSS” to “yes” and “Use Encryption” to “yes”.
Hi. Thanks for your help. I’ve made these changes as you suggested but the symptom remains exactly the same :frowning:
Any firewall rules?
Only NAT and protection against DNS amplification attacks, nothing that would be related to pptp problem:
[admin@xpto] /ip firewall> export
# sep/23/2013 14:33:44 by RouterOS 6.4
add action=drop chain=input comment="Protection against incoming external DNS queries" dst-port=53 protocol=udp src-address=\
    !192.168.77.0/24
add action=drop chain=input comment="Protection against incoming external DNS queries" dst-port=53 protocol=tcp src-address=\
    !192.168.77.0/24
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway to-addresses=0.0.0.0
add action=dst-nat chain=dstnat comment="Torrent DMZ" dst-port=51413 protocol=tcp to-addresses=192.168.77.200 to-ports=514
