PPTP connection for hotspot users
i’m trying to connect some of my hotspot users throw PPTP connection and I tried a lot i can’t get it to work any help?
i have followed those tutorials
http://gregsowell.com/?p=680
http://wordpress.wlevels.nl/configuring-routeros-as-pptp-client/
and many others but it does not work no traffic going throw the PPTP
pls any idea ??
Regards
Update1:
I did get it to work by following this
http://unblockvpn.com/support/how-to-set-up-openvpn-on-router-mikrotik.html
now i want a way to only get some users to use this connection not all users as it now
so any idea ???
Update2:
i have add mangle to mark route of the user IP then i did not remove the defult gateway as the tutorial say and i make another defult route but i add the mark
it work but it did not forward all the traffic (of specified IP) throw PPTP !! any one have any idea
Hotspot is a L2 service, you’ll need to run a L2 protocol such as EOIP to have Hotspot working over PPTP.
ok thanks i have read the wiki
http://wiki.mikrotik.com/wiki/Manual:Interface/EoIP
put did not understand how i can use it with pptp ??
any help!
or both servers should use EOIP
the other server have CentOS installed on it what should i do ?
by reading some websites they say that this can be done throw OpenVPN is that true??
if yes any one know how to do it ?
try using l2tp
thanks
do you have any links or tutorials ???
