PPTP Server Binding Status wrong
I have 2 x R2011i routers
Router 1 is a PPTP server
Router 2 is the Client
When Router 2 connects to Router 1 , the PPTP server binding status shows connected. When I then disable the PPTP client on Router 2 the PPTP server binding on Router 1 still says connected even though there is nothing under active connections.
How can I fix this problem ?
Please reproduce this problem again (when tunnel is not connected but you still see it) and generate supout file on your router. Send this file to support@mikrotik.com together with reference to this forum topic.
