I’ve looked over the forums and found alot of older posts saying that i need to enable arp-proxy in order for PP2P to work with vlans. Is this still the case? And if it is, exactly on which interface do i need to enable it? Do i need to enable it on every interface the Vlan touches over our whole network? What are the side effects?
Better yet, does anyone know of another way to link a remote site (via internet) back to my MT router, and still route traffic over (it)?
EoIP tunnel would be complete ethernet interface replica and OSPF, for example, cannot see a difference between EoIP tunnel and real ethernet interface.
Router 1 has 10.1.1.0/24 range on a bridge, with a VLAn & Eth as ports
Router 2 has 192.168.1.0/24 range on eth interface
I set up routes, so either router can see each other and ping each other, and anything directly connected to the router, but when router 2 tries to ping anything on the vlan, it wont respond. But a router on the vlan (10.1.1.0/24 range) can ping the 192.168.1.0/24 range perfectly.
I searched the forums and found that there is a problem with PPTP & Vlans / Bridges and that i may or may not need to enable Arp-proxy.
