I am experience some performance issues on my RB 750. Its running RouterOS 6.33.3 and FW version 3.24. I am not running a HotSpot, no queues and about 20 firewall rules.
Over NAT i am currently only getting about 210mbit/s of my line that should be 250mbit/s. I have of course tried it without the RB, and gotten the full speed. Furthermore, i have tried turning off all the firewall rules, and that only increases the throughput by 15mbit/s.
So my question is this. Have i simply reached the limit of what my RB can do? Or is there something i am missing in respect to configuration.
Do you have FastTrack enabled and is it working? Depending on what RB750 model you have (assuming it’s not the plain as that’s 10/100 only) you might be hitting the limit without FastTrack.
/ip settings print
Look at the ipv4-fasttrack-active and ipv4-fasttrack-packets.
I was indeed peaking the capabilities of the router. The CPU was peaking. The reason why i did not suspect this at first, was that the CPU peaked and blocked the GUI update before the counter got to 100% - leaving me with a stable far lower number. I figured this out by doing a speed test with a ramp up start.
Thanks for good and insightful replies. I solved the problem by buying the 3011.
And no, FT was not enabled. But a good point, i will dig out the old 750 and see if that has an effect.
