Hello any other script to prevent share id with different mac address ? its impossible for me to register every mac address at userman with more than 100 different user every month, because im tired to seeing they keep share 1 id with 2 different mac address and make my business loosing money
they are not login 1 id simultaneously just sharing id after their friend logout and not using hotspot , Thank you sorry for my bad english
You can use “caller-id-bind-on-first-use” when creating a new user. The caller-id is actually the MAC address for hotspot and PPPoE connections (which is what I’m guessing you’re using User Manager with). When using that option, the caller-id will be determined based on the device the user logs in from, so you don’t need to fill anything.
Thank you sir its work , you solve my problem , may god bless you ![]()
Thread closed
Hi I am new with user manager , actually this works when I create users manually but I need an script to automatically enable the bind mac as it is a platform API which creates and does not allow you this option when create, in specific is the wp 500 pm who creates users
