I am new working with Mikrotik and in this forum. I have a Mikrotik Administering the network as a firewall, QoS, NAT, DHCP, etc. and I need to prevent bruteforce attacks for MySQL and MSSQL servers. I tried something like this:
It works passing connections through stages but, even if I put the correct user and password my IP gets blacklisted. I think there must be a way to verify invalid login adding a characteristic to the rules, but I do not know what could it be.
I have done similar rules for SSH bruteforce attacks and RDP attacks and it works fine.
Router is not the right place for this. It would have to inspect connections, understand the protocol and find failed login attempts. You’d need L7 filters and even if it’s possible to find the right patterns (I don’t know), it’s resource-intensive stuff.
If it seems to work for SSH or RDP, it’s only because when you connect and log in, typically the connection stays open for a longer time and you don’t reconnect several times. But try to open several connections quickly after each other and you’ll be blocked too.
For any SQL, I’d say it’s completely unusable. Have e.g. typical webserver with php and unless you use persistent database connections, you’ll get new ones all the time. And even with persistent ones, restart webserver, several php cgi processes will start at the same time, connect to database … and you’re blocked again.
Personally I’d rather have a whitelist of allowed addresses, if possible. If it’s open for everyone, I wouldn’t fear bruteforcers too much. Network has some minimum latency, so it’s natural limit, you can’t try million passwords every second. So with strong passwords, they could try for a century and won’t get in. But if it would happen that some exploitable vulnerability would be discovered in database, then just one connection could be enough.
Either a professional or security conscious technical individual would only ever be either using network segments like VLANs (non-Internet) or a single firewall point of entry on a dedicated edge device (Internet). So, these types of attacks would be all but impossible to occur to production server in the first place.
The rest is taken care of by logging and usual security practices
In your case, you should be using a VPS or VPN, though if you had to you could use a strong SSH implementation with key-based authentication instead (this latter setup is the only one where fail2ban or similar would make sense).
If you really need to release directly Mysql. I would recommend the use of certificates, and write a script. Who will look into the events. And with a large number of authorizations, send a mikrotik to the block list. Ideal: to exclude direct access and use VPN.
p.s. : If you need hardcore. Install cyg-win. and try to compile fail2ban)
