Try the command ‘export’ you do it in a specific directory to only save those settings if needed.
You can also just use the backup & restore system.
Export outputs a text file with all the commands, I don’t think backup is a text file that can be read.
You might want to only export certain parts, exporting the whole configuration may generate too large of a file to easily use.
Using export via terminal is the best way to “see” your config in it’s raw format. A slightly more person friendly approach would be to do something like;
export file=myrouterexport
This saves the export locally.
Then using Winbox go into “Files” and download the complete RSC file.
