Hello members,
In mainland China (PRC), due to limited IPv4, most of customers (private IP) can only connect to the Internet via CGNAT (Carrier-Grade NAT). However they have internal IP cameras or router(s), external public IP cannot directly connect them due to internal IP.
The following diagram shows the connection:
private IP router (R1) —> router (public ISP) —> Internet —> public IP router (R2) <— notebook PC
In R1 (NAT) we can connect to R2 using the site-to-site method. R2 cannot connect R1 because R1 is private IP.
We use two PC WireGuard configuration files (Table 1 for router R1 and Table 2 for user) in a notebook PC. The notebook PC tests two configuration files without any problems. The router R2 WireGuard server is showed in Table 3. In fact R2 can be any WireGuard server and do not be a MikroTik router. Based on the Table 1 settings, it builds the configuration in Table 4.
Since routers are used in mainland China (PRC) and if you switch to other countries, the following items:
- DNS in Table 1 and 2 should be changed to 8.8.8.8 or omitted to use local DNS servers
- Endpoint adc.xyz.org in Table 1, 2 and 4 should be changed the corrected one.
- Some values in Table 4 is based on Table 1 such as
a) Table 1 address is 10.2.100.5/32 changed to 10.2.100.5/24
b) The persistent-keepalive=25 must be in place since R1 is in private IP and keep the line connected - In R1 firewall filter should allow WinBox tcp=8291 and ICMP to allow ping
Operation:
- In the router R1 used codes in Table 4 such that R1 is connected to R2
- Open the PC notebook any place and connected the Internet.
- Click the WirGuard icon and then select “fs-gu-us” in Table 2 to connect to router R2
- Open WinBox and select “10.2.100.5”, admin/password to connect R1 the private IP router.
Remarks:
- This is the same as Back-To-Home and not limited to ARM CPU.
- Many MikroTik routers RB5009, CCR1009 are tested without any problems.
Table 1: PC WireGuard configuration file for R1 to server R2
#fs-gu-mt
#PublicKey = 6SS1XAlmf2kYDr/tl0fHnVyTgWATeRyf/CKY1tgLTjE=
[Interface]
PrivateKey = mNFjsoTI5IQqMsRlT8uCN6Hkwd1s3J10QEYqOFI/pGU=
Address = 10.2.100.5/32
DNS = 223.5.5.5, 119.29.29.29
[Peer]
PublicKey = pHfm7nZ/PTR0A7ca5I5gVJqr1bTS6eXL0wB4v8cl+RU=
PresharedKey = +LTmCJ3lK4HKRsDzBis4omPjMSLEIJ6qsUTxbwU6x1s=
AllowedIPs = 0.0.0.0/0
Endpoint = abc.xyz.org:60279
PersistentKeepalive = 25
Table 2: PC WireGuard configuration file for user to server R2
#fs-gu-us
#PublicKey = 9XfvhtbOjt5f6R+KZptEuifQ9sTRPmPrmy2Tax0ZPhg=
[Interface]
PrivateKey = cIvH/Z9TIcp5EHRmUhyRnthUu2D5TQhVuuxshFrSPFc=
Address = 10.2.100.2/32
[Peer]
PresharedKey = 4LHcT1qU4ybbILKpOWw2by/pQhVZt9jrApUC9NmDg3Q=
Table 3: R2 WireGuard server settings
#R2 WireGuard server
#PublicKey = pHfm7nZ/PTR0A7ca5I5gVJqr1bTS6eXL0wB4v8cl+RU=
[Interface]
PrivateKey = KPje8vVVILP7WeR9cOmlfYYfmcni1sCNeAFB61Hk/EA=
[Peer]
[Peer]
Table 4: Router 1 WireGuard settings based on Table 1
/interface wireguard
add listen-port=13232 mtu=1420 name=wg-fs private-key=\
"mNFjsoTI5IQqMsRlT8uCN6Hkwd1s3J10QEYqOFI/pGU=" \
comment="WG FS"
# Assign address to the router on the new interface.
add address=10.2.100.5/24 comment="Wireguard" interface=wg-fs \
network=10.2.100.0
# Set up FS peer
/interface wireguard peers
add name=fs allowed-address=10.2.100.5/24 comment="fs" \
endpoint-address=abc.xyz.org endpoint-port=60279 \
interface=wg-fs public-key=\
"pHfm7nZ/PTR0A7ca5I5gVJqr1bTS6eXL0wB4v8cl+RU=" \
preshared-key="+LTmCJ3lK4HKRsDzBis4omPjMSLEIJ6qsUTxbwU6x1s=" \
