problem about user name in noip.com script.
Currently I be a member of NOIP.com and paid for the yearly charge. In my NOIP Account I could separate each host to each password. Please look at picture below.
My problems is the use name is contain the symbol “:” (Colon). When I put the user name for example “nj:nj@corecasys.com”. The script will not available. Because the symbol “:” is a part of command in the script. Even I put “” in this code it still not available.
How do it put symbol ‘:’ (Colon) as a user name in my script ??? Please accept my extreme thanks for your kindness in advanced.
example my script
Set needed variables
:global username "nj:nj@corecasys.com"
:global password "password"
:global hostname "njexample.corecasys.net"
:global wanInt "pppoe-out1"
:global noipForce
:global previousIP2
print some debug info
#:log info ("DDNS: username = $username")
#:log info ("DDNS: password = $password")
:log info ("DDNS: hostname = $hostname")
:log info ("DDNS: previousIP = $previousIP2")
Grab the current IP address on that interface.
:global ddnsip [/ip address get [/ip address find interface="$wanInt"] address]
:global currentIP [:pick $ddnsip 0 [:find $ddnsip "/"]]
#:log info ("DDNS: ddnsip = $ddnsip")
:log info ("DDNS: currentIP = $currentIP")
Remove the # on next line to force an update every single time - useful for debugging, but you could end up getting blacklisted by No-IP!
#:set noipForce true
Determine if no-ip update is needed
more no-ip updater request details available at http://www.no-ip.com/integrate/request/
:if (($currentIP != $previousIP2) || ($noipForce = true)) do={
:set noipForce false
:set previousIP2 $currentIP
:log info ("DDNS: No-IP update needed")
:log info ("DDNS: Start of Fetch")
global tmp [/tool fetch mode=http port=80 address=dynupdate.no-ip.com host=dynupdate.no-ip.com src-path="/nic/update?hostname=$hostname&myip=$currentIP" user=$username password=$password dst-path="/noip2.txt"]
:log info ("DDNS: End of Fetch")
:global result [/file get noip2.txt contents]
:log info ("DDNS: No-IP Update Result: $result")
:put ("No-IP Update Result: $result")
Update HE.net Tunnel
:execute script=HE-NET
} else={
:log info ("DDNS: No No-IP update needed")
EDIT: added details, see next post
Thank ‘restended’. You may not understand my question. If you read it carefully. You will not said “Why you complicate your life uselessly?”. :slight_smile:
My email just ‘nj@corecasys.com’. In part of the ‘nj:nj@corecasys.com’. The NOIP defined that if i want to used difference password for each host name. I must created group name and follows by my email which i were applied with the NOIP. Please read carefully in picture below.
However thank for your try.
:global username "\"nj:nj\"@insertspammersitehere.com"
your code was not work.
Is not my code…
https://datatracker.ietf.org/doc/html/rfc2822#section-3.2.1
P.S.:
why http and not httpS?
fetch do not support redirect.
You read the instructions?
Like not…
Authorization: base64-encoded-auth-string should be the base64 encoding of username:password.
GET /nic/update?hostname=mytest.example.com&myip=192.0.2.25 HTTP/1.1
Host: dynupdate.no-ip.com
Authorization: Basic base64-encoded-auth-string
User-Agent: Company DeviceName-Model/FirmwareVersionNumber > maintainer-contact@example.com
For example
nj:nj@corecasys.com = bmo6bmpAY29yZWNhc3lzLmNvbQ==
and must you encode also the password inside…
My I ask why you don’t use the buildin service in MikroTik?
/ip/cloud
Probably because is not the domain “jeff.corecasys.net”…
rextended > I don’t understand your answer. My question is simple. How to solve my user name “nj:nj@corecasys.com”. Please see picture below.
for the code as i mentioned above. It working properly if i use the normal user name standard format..
erlinden > i don’t use ip/cloud because the ip cloud format is not human reading. It’s very diffiult to remember.
I-have-already-reply-to-you-on-previous-post
But I have also readed the instruction on noip.com
You read the instruction for group update or you are able only to copy&paste?
https://www.noip.com/integrate/request
Also why you do not ask help where you copy & paste the script? (January 14, 2014)
https://robby1609.wordpress.com/2014/01/14/simple-script-for-dynamic-ip-public-on-mikrotik-using-no-ip/
The script is 9 years old
Or from the (probably) original authors? (Desember 15, 2012)
https://hendrainfo.wordpress.com/2012/12/15/membuat-ip-dynamic-menjadi-static-menggunakan-no-ip-com-via-mikrotik/
NO… is 11 years old
NO… one moment…
Is stolen again from here (11 Jan 2012)
http://forum.mikrotik.com/t/no-ip-and-he-tunnel-scripts-for-v5-11/53253/1
You understand that after 12 years syntax can be changed?..
(The script is for RouterOS 5.11)
