Hello everybody,
Nowadays I have problem connecting remotely as a user to mikrotik using winbox. Also problem to connect with webfig. In some Public IPs it works but in majority of them not. Do anybody have any informations about this issue?
The request of winbox is: could not connect to…IP!
Thanks,
Faton
Hello
You don’t offer much information. Do you mean that you wish to connect from the internet? I hope you use a vpn or port knocking or something to protect yourself otherwise your telling us that your router is wide open.
Otherwise, there’s no current issue with connecting via winbox unless someone closed some ports outbound. Shouldn’t be the case with port 80 though.
Regards
Sent from Tapatalk
