problem on RB500: aes handshake with rc10
Hello ,
i had a rb500 with rc7 running. The wireless interface had aes encryption enabled and the clients too (clients: wpa-supplicant).
Worked fine until upgrade of the rb500 from rc7 to rc10. the wpa-supplicant works fine with aes on together with other aps supporting wpa/aes.
Since I upgraded to c10 the rb500 reports a group key update timeout (16) … (see att. Pic)
I generated a supou.rif (attached)
For now I changed the enc. to tkip … this works for now.
Can you help me with this error ? i´d like to use aes for encryption.
Regards
jochen
http://www.hostalka.com/supout.rif < supout.rif
http://www.hostalka.com/clip_image002.jpg < winbox - log -screenshot
Yes, I have exact the same problem after upgrating from RC7 to RC10.
All my clients used WPA-PSK with AES encryption. After upgrade to RC10, no client is able to register by using WPA-AES encryption. TKIP instead still works.
My clients are Windows-XP SP1/2 machines and Linux-machines using WPA-Supplicant. With RC7, aes worked fine.
Changelog of RC9 says: *) fixed bug - AES group key handshake failed
Really fixed? Before fixing, I had no problems :wink: Perhaps, a second fix is necessary :wink:
