-Routerboard RB5900
-LAN-Bridge contain eth4, this is in trunk with pvid 90, admit all
-WAN-Bridge contain eth2, no vlan filtering
I also add this route:
0.0.0.0/0 to 192.168.1.254
Now, all works fine, I can navigate with PC and have no error, but from WAN-Bridge I can’t ping any address on LAN-Bridge
I need to set a port forwarding; i try to set it to 192.168.1.250 on port 22 and works fine, but I can’t reach 192.168.7.254 on port 22
Traceroute from RB5009 from WAN-Bridge to 192.168.7.254
1 - 192.168.1.254
2 - 10.2.3.94
3 - timeout
I could try but do not understand your setup.
What seems to be true is that there is an upstream ISP modem/router that provides you with a private IP address.
For some strange reason you are feeding a cisco switch instead of the RB5009 directly.
Not sure why you are having multiple links from the switch to the RB5009 as this makes no sense to me???
If for some physical reason this has to be the way what you are doing appears to be a tad strange.
In other words first recommendation is remove cisco and perhaps use it after the RB5009 if more ports are required.
If not, then
a. Understand you want vlan10 to be “like” the incoming internet feed and thus
tag the feed from the ISP router with vlan10, and carry it through to the RB5009.
Trunk port from cisco to RB5009 .
I would then terminate that on the RB5009 and create as many vlans behind the RB5009 as required.
One would a management vlan, like vlan99 which the CISCO would also have on the trunk port and the CISCO would get its IP address on this subnet.
