Problem pinging IP assigned to bridge, on tagged port - works fine for other hosts
I have a really basic question that I’m having trouble with. I have one bridge created that’s working fine with tagged and untagged ports. I created an IP address 192.168.100.253/24 and assigned the bridge as it’s interface, as tagged.
[admin@MikroTik] > /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   192.168.100.253/24 192.168.100.0   bridge2VLANCluster
 1 D 192.168.1.236/24   192.168.1.0     ether24
[admin@MikroTik] > /interface bridge vlan print
Flags: X - disabled, D - dynamic
 #   BRIDGE        VLAN-IDS  CURRENT-TAGGED        CURRENT-UNTAGGED
 0   bridge2VLANCluster        100       bridge2VLANCluster
        ether2
        ether3
        ether4
        ether1
 1   bridge2VLANCluster        200       ether1        bridge2VLANCluster
        ether10
        ether11
        ether12
 2 D bridge2VLANCluster        1        bridge2VLANCluster
        ether24
        ether1
Hosts on ether1,2,3 and 4 can ping each other fine on the 192.168.100.0 network but from my host on ether1, which has a tagged interface 192.168.100.10, I’m not able to ping 192.168.100.253. What am I doing wrong? I want to have 192.168.100.253 available as an address for hosts isolated on 192.168.100.0 to use services like NTP. I don’t have any firewall rules configured on the MikroTik or the hosts.
RouterOS v6.49.18 (long-term)
Architecture Name arm
Board Name CRS326-24G-2S+
If bridge CPU-facing port is tagged, then you have to create VLAN interface (under /interface/vlan), anchor it to bridge CPU-facing port with corresponding VLAN ID set and use that interface to set up IP address (etc.). Setting IP address directly on bridge switch-facing interface works only if bridge is (also) untagged.
What if the bridge is a hybrid, tagged and untagged ports?
Not all that unexpected: untagged packets are available on the “bridge” interface for processing in the ip stack. Tagged packets are extracted (and encapsulated in the other direction) by the vlan interfaces and are available there.
Having a hybrid cpu port (“bridge” as port) isn’t really a common configuration, but it works in the expected manner.
Do you mean like this? I created a new interface, ‘vlan100interface’ and added my 192.168.100.253 IP to it but I get this error-
[admin@MikroTik] > /interface vlan print
 #   NAME        MTU ARP             VLAN-ID INTERFACE
 0 R vlan100interface
        1500 enabled             100 bridge2VLANCluster
 0   192.168.100.253/24 192.168.100.0   vlan100interface
 0   bridge2VLANCluster        100       ether2
        ether3
        ether4
        ether1
        ether10
        ether11
        ether12
        ether24
        ether1
[admin@MikroTik] > /interface bridge vlan add tagged=vlan100interface vlan-ids=100 bridge=bridge2VLANCluster
failure: vlan already added
Bridge2vlancluster has to be added as tagged port, not the vlan interface. (To itself…)
If you’re running a fairly recent software, this is added automatically as a dynamic vlan entry when you add the vlan interface.
Otherwise you’re on the right path.
EDIT: now I think it’s working - I added bridge2VLANCluster to itself.
Thanks for your help on this. I tried this but it still isn’t working-
[admin@MikroTik] > /interface bridge port add bridge=bridge2VLANCluster frame-types=admit-only-vlan-tagged interface=vlan100interface pvid=100 hw=yes
[admin@MikroTik] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE        BRIDGE        HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0   H ether2        bridge2VLANCluster        yes  100     0x80         10                 10       none
 1   H ether3        bridge2VLANCluster        yes  100     0x80         10                 10       none
 2   H ether4        bridge2VLANCluster        yes  100     0x80         10                 10       none
 3   H ether10        bridge2VLANCluster        yes  200     0x80         10                 10       none
 4   H ether11        bridge2VLANCluster        yes  200     0x80         10                 10       none
 5   H ether12        bridge2VLANCluster        yes  200     0x80         10                 10       none
 6   H ether1        bridge2VLANCluster        yes    1     0x80         10                 10       none
 7   H ether24        bridge2VLANCluster        yes    1     0x80         10                 10       none
 8     vlan100interface        bridge2VLANCluster        100     0x80         10                 10       none
Again, you don’t enroll the vlan interface as a port. You enroll the bridge interface.
  1. Remove the vlan interface from bridge ports. (Assuming that numbering remains the same.)
    /interface bridge port remove 8
  2. Add the bridge as tagged port to itself.
    /interface bridge vlan add bridge=bridge2VLANCluster tagged=bridge2VLANCluster vlan-ids=100
  3. Configure the bridge cpu port to accept the frames: (Assuming you only have the one bridge, otherwise renumber.)
    /interface bridge set 0 frame-types=admit-only-vlan-tagged ingress-filtering=yes
Awesome! Thank you
