I updated my 951 router to version V7, and since then, the redirection to the hotspot login page has stopped working. I also tried restoring the backup, but it was impossible to redirect to the hotspot login page.
My hotspot system is no longer working.
Can I have some assistance, please?
Hi there, can you post your configuration with the private bits removed? See here fir help on how to do so.
If you backed up to v6 but keep reloading it from v7, it won't work if it's already not working when upgraded.
To speed up the process of restore the fuctionality, downgrade with previous v6.x.x and reload the backup.
Then ask for assistance on the forum on how to migrate from v6 to v7, preparing everything you need first.
That's assuming the hotspot migration can be done without problems, depending on how you use it.
Even if you export on "broken" v7, some pieces may have been lost from the migration from v6,
which may be just in the backup, without having made a .rsc with the show-sensitive export before the upgrade.
Hello team, I bought a new 951 v7 router. I configured everything on the internet side. So I created the hotspot server, but I am not redirected to the login.html page. And when I go to firewall and nat (no redirection configuration) I see after the hotspot setup creation the profile turns red so that means the system does not work despite I updated the router to v7.19.5
Reading the first post, it says:
I updated the 951 (from v6) to v7, and after the upgrade the hotspot has stopped working (which means it was working before).
Reading the second post, it says:
I bought an 951 with v7 already installed, but I can't get the hotspot to work, even though I updated it to v7.19.5.
There is too much of a discrepancy for my taste.
And I'll add: There are many products with "951" in their names, and they're quite different from each other.
We need to be more specific.
https://mikrotik.com/product/RB951Ui-2HnD
https://mikrotik.com/product/RB951Ui-2nD
https://mikrotik.com/product/RB951-2n
Hello team
I have Mikrotik RB951Ui-2HnD version 7.19.6 (stable)
I configured the hotspot server, but the hotspot went red, so if it's not good, can I have some scripts for commands to activate the hotspot?
code print here:
[admin@WIFI ZONE CISSE] /ip/hotspot> print
Flags: I - INVALID
Columns: NAME, INTERFACE, ADDRESS-POOL, PROFILE, IDLE-TIMEOUT
NAME INTERFACE ADDRESS-POOL PROFILE IDLE-TIMEOUT
;;; inactivated, not allowed by device-mode
0 I hotspot1 HOTSPOT dhcp_pool1 hsprof1 5m
profile print
[admin@WIFI ZONE CISSE] /ip/hotspot> profile/
[admin@WIFI ZONE CISSE] /ip/hotspot/profile> print
Flags: * - default
0 * name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot
html-directory-override="" install-hotspot-queue=no http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d
split-user-domain=no use-radius=no
1 name="hsprof1" hotspot-address=10.10.10.1 dns-name="www.wifizone-cisse.com>
html-directory=hotspot html-directory-override=""
install-hotspot-queue=no http-proxy=0.0.0.0:0 smtp-server=0.0.0.0
login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no
use-radius=no
Can you send the output of
/system/device-mode/print
Hello, the problem was due to the mode, it was home and I changed to advanced interface hotspot mikrotik came thanks
bonjour monsieur, svp comment vous avez puis arriver a corriger cela car j'ai le même problème, j'ai acheter un mikrotik RB951 et c'est la version v7.18 mais le hotspot est invalide quand je le configure
