Hi everyone, i’m upgrading my room with some network controlled devices (smart lights etc.) and because i share the network with some other people i wanted to divide the network into subnets for security.
The network:
Subnet A - 192.168.88.0/24
Gateway: 192.168.88.1
Open for all users.
Subnet B - 192.168.80.0/24
Gateway: 192.168.80.1
Private network.
The internet router is located in subnet A with the static IP address 192.168.88.254 and running NAT.
The problem
Locally it all works perfectly, subnet A can ping subnet B and vice versa. Both can ping and access the internet router. But i only have internet on subnet A, on subnet B i can’t get a internet connection. I checked with torch and the internet traffic is going out because when i ping 8.8.8.8 from subnet B - 192.168.80.2, i see a reply coming back with src 8.8.8.8 and dst 192.168.80.2 on the subnet A bridge interface. But it isn’t routed to subnet B for some reason.
When i masquerade the traffic comming from subnet B the internet is working, but i don’t want double NAT.
I’ve been working on this for the last couple of days and i’m all out of ideas. So if someone has a solution or a push in the right direction i would really appreciate it!
(As a side note: when everything works i will block traffic between subnets)
Configuration
I have a RB951G-2HnD running version 6.29.1 as the main router and a Cisco EPC3925 as the internet gateway.
I divided the network into 2 bridges:
[admin@MikroTik] > interface bridge print
0 R name="bridge-local" mtu=1500 actual-mtu=1500 l2mtu=1598 arp=enabled
mac-address=D4:CA:6D:F2:CD:B9 protocol-mode=rstp priority=0x8000
auto-mac=no admin-mac=D4:CA:6D:F2:CD:B9 max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m
1 R name="bridge-local-private" mtu=1500 actual-mtu=1500 l2mtu=1598
arp=enabled mac-address=D4:CA:6D:F2:CD:BC protocol-mode=rstp
priority=0x8000 auto-mac=yes admin-mac=00:00:00:00:00:00
max-message-age=20s forward-delay=15s transmit-hold-count=6
ageing-time=5m
[admin@MikroTik] > interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether2-master-local bridge-local 0x80 10 none
1 wlan1 bridge-local 0x80 10 none
2 MyPrivateNetwork bridge-local-private 0x80 10 none
3 I ether5-master-local-private bridge-local-private 0x80 10 none
[admin@MikroTik] > interface wireless print
0 R name="MyPrivateNetwork" mtu=1500 mac-address=D6:CA:6D:F2:CD:BD
arp=enabled interface-type=virtual-AP master-interface=wlan1
ssid="MyPrivateNetwork" wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=private
1 R name="wlan1" mtu=1500 mac-address=D4:CA:6D:F2:CD:BD arp=enabled
interface-type=Atheros AR9300 mode=ap-bridge ssid="PucksPartyHouse"
frequency=2412 band=2ghz-onlyn channel-width=20mhz scan-list=default
wireless-protocol=802.11 wds-mode=disabled wds-default-bridge=none
hide-ssid=no security-profile=default compression=no
Each bridge has is own subnet and DHCP server:
[admin@MikroTik] > ip address print
# ADDRESS NETWORK INTERFACE
0 ;;; default configuration
192.168.88.1/24 192.168.88.0 bridge-local
1 ;;; Private network configuration
192.168.80.1/24 192.168.80.0 bridge-local-private
[admin@MikroTik] > ip pool print
# NAME RANGES
0 default-dhcp 192.168.88.10-192.168.88.254
1 private-dhcp 192.168.80.2-192.168.80.254
[admin@MikroTik] > ip dhcp-server print
# NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 default bridge-local default-dhcp 3d
1 private bridge-local-private private-dhcp 3d
[admin@MikroTik] > ip dhcp-server network print
# ADDRESS GATEWAY DNS-SERVER WINS-SERVER DOMAIN
0 ;;; private network configuration
192.168.80.0/24 192.168.80.1 192.168.80.1
1 ;;; default configuration
192.168.88.0/24 192.168.88.1 192.168.88.1
[admin@MikroTik] > ip dns print
servers: 8.8.8.8,8.8.4.4,192.168.88.254
dynamic-servers:
allow-remote-requests: yes
max-udp-packet-size: 4096
query-server-timeout: 2s
query-total-timeout: 10s
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 79KiB
Most routes were added dynamically and i only added a static route for the internet gateway:
[admin@MikroTik] > ip route print
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.88.254 1
1 ADC 192.168.80.0/24 192.168.80.1 bridge-local-pr... 0
2 ADC 192.168.88.0/24 192.168.88.1 bridge-local 0
I have no mangle, firewall and NAT rules enabled:
[admin@MikroTik] > ip firewall filter print
[admin@MikroTik] > ip firewall nat print
0 X ;;; default configuration
chain=srcnat action=masquerade to-addresses=192.168.88.0/24
src-address=192.168.80.0/24 out-interface=bridge-local log=no
log-prefix=""
[admin@MikroTik] > ip firewall mangle print
