Problem with accessing Public Ip of DMZ Server from DMZ
I have 3 NIC for Local, Internet, and DMZ. The print out are :
[admin@gateway] interface> print
Flags: X - disabled, D - dynamic, R - running
NAME TYPE RX-RATE TX-RATE MTU
0 R Internet ether 0 0 1500
1 R Local ether 0 0 1500
2 R DMZ ether 0 0 1500
In The Address List I already input several ip address, the print out are :
[admin@gateway] ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 202.xxx.21.184/27 202.xxx.21.160 202.xxx.21.191 Internet
1 202.xxx.21.171/27 202.xxx.21.160 202.xxx.21.191 Internet
2 202.xxx.21.168/27 202.xxx.21.160 202.xxx.21.191 Internet
3 192.168.0.184/24 192.168.0.0 192.168.0.255 Local
4 192.168.10.17/24 192.168.10.0 192.168.10.255 DMZ
And I input the dst nat for proper inbound nat, the print out are :
[admin@gateway] ip firewall dst-nat> print
0 dst-address=202.xxx.21.171/32 action=nat to-dst-address=192.168.10.33
1 dst-address=202.xxx.21.168/32 action=nat to-dst-address=192.168.10.168
Dst Nat rule no 0, used for outbound connection from internet to Server A network
Dst Nat rule no 1, used for outbound connection from internet to Server B network
For the Src nat for proper outbound nat, the print out are :
[admin@gateway] ip firewall src-nat> print
0 src-address=192.168.10.33/32 action=nat to-src-address=202.xxx.21.171
1 src-address=192.168.10.168/32 action=nat to-src-address=202.xxx.21.168
2 src-address=192.168.0.0/24 action=nat to-src-address=202.xxx.21.184
Src Nat rule no 0, used for outbound connection from Server A network to internet
Src Nat rule no 1, used for outbound connection from Server B network to internet
Src Nat rule no 2, used for outbound connection from local network to internet
For forward chain I input the following rule, some of the print out are :
0 add src-address=202.xxx.21.160/27:0-65535 in-interface=all
dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=all
icmp-options=any:any tcp-options=any connection-state=any flow=""
connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0
limit-burst=0 limit-time=0s action=accept log=no comment="" disabled=no
1 ...
The Outbound connection to internet working good for Local Network(192.168.0.0/24),
Server A (192.168.10.33) and Server B (192.168.10.168).
And The Connection From Internet to Server A and Server B working good.
Case I:
But the problem is begin when I try to connect to Server B using the hostname of Server B (mybox.B.com)
which resolve to the public Ip Address (202.xxx.21.168), through Server A The connection always failed.... I tried to ping to 202.xxx.21.168, I always get the reply from Server B
Case II:
The Same problem occur when I try to connect to Server A (mybox.A.com) from the Server B
My solution for Case I:
I tried to bypass the hostname resolve from dns server by using dns cache, so when I want to connect
to Server B (mybox.B.com) it will resolve to DMZ address (192.168.10.33) instead the public one. And the same with problem with Case II
Can anyone help me to solve my problem :
How I can connect to Server B's public Address (202.xxx.21.168) through Server A,
b'cos I had no domain name for the Public IP address?
Thanks in Advance
You could try putting the local addresses in the hosts file on each server. That will take precedence over DNS.
Regards
Andrew
Why can’t I just use the public IP instead the hostname of the public ip?
What’s wrong with my config?
Some of the program just use the public IP instead the hostname, so how I can make it connect to other Server B from Server A?
I Need Soultion to make it work?
In Cisco Router with DMZ configuration, it make me more confuse..
The same problem occur also…, when i try connect to the Server B’s IP public
But when I try to resolve for the hostname (mybox.B.com), it automatically resolve to 192.168.10.168
NOTE: I used the ISP DNS (202.xxx.xxx.xxx) not DMZ IP’s in Mikrotik (192.168.10.17)
In DNS server I never input the DMZ Ip (192.168.10.168) for the mybox.B.com, It make me confuse how It can happen?
Is it mikrotik can not make the connection to other server behind DMZ’s Firewall Network from other server behind the DMZ’s Firewall Network ?
Could u explain me this?
:question:
Is there something I can do in the mikrotik’s configuration to make it works?
