Problem with bonding and ping vs vdsl router
Hello at all,
i’m very new about mikrotik, i use this product in my home from 1 years and now i’ve implemented a new configuration for my new client, this is the situation.
2 vdsl router with ip 10.0.0.1 and 10.0.10.1 connect to ether 1 (10.0.0.2) and ether 2 (ip 10.0.0.2)
In mikrotik the port 3 is connect to switch and serve a dhcp with class 192.168.1.0/24 , the port 4 is connet in the same switch and serve dhcp with 192.168.0.0/24 (the port from 1 to 11 get class 1.0/24 and rest 0.0/24)
Al work great but only if one vdsl is connected, with both vdsl the navigation became very very very slow.
I’ve tried a ping vs 8.8.8.8 and with both vdsl connected i lost lot of packets, with only one is perfect.
The same problem happen if ping the internal ip of the router with ip 10.0.0.1, while the ping work properly on router with ip 10.0.10.1
Ive tried new cable but nothing, if i connect with laptop on vdsl router with ip 10.0.0.1 the ping is ok as the navigation, I suppose the problem is not the vdsl router but the port of mikrotik or the bonding.
Now the bonding is set as balance rr with transmit hash policy mayer 2 and layer 3
I hope to be clear
Thank is advance
