i install mikrotik router os in one pc with hardware
1-cpu 3000 athlon 64 bit mikrotik detected 2210
2-2*1gig ddr memory mikrotik detected 116 Mib
problem in deteted low memory is very hot.plz help me for bad detected my memory ![]()
well upgrade
you say 2.9.?
we are working on 3.30
so i wonder how many bug fixes there are from 2.9 to 3.30 lets look
i can only find this on v3 so upgrade and see if it fixes you problems first
Whatâs new in 3.30:
*) added connection-rate matcher;
*) receiving too large frame (>1540 bytes) does not hang ether1 on RB4xx;
*) fixed ping - value of âsrc-addressâ was ignored since 3.23;
*) api - limited maximum allowed word length to 65536;
*) fixed IPv6 Router Solicitation message handling;
*) special-login - port could remain used by âspecial-loginâ even after
user logged out. fixed;
*) bonding in active-backup mode and arp link monitoring works when no switch
between endpoints;
*) routing, routing-test - fixed route redistribution crash;
*) ups - show voltage in .01V units;
*) console - âtorchâ and âwireless scanâ commands have new argument
âdurationâ that approximately limits running time of the command;
*) api - âtorchâ and âwireless scanâ commands now return same values
in â!reâ responses as in console (before they didnât return
anything), â.proplistâ is also correctly handled;
*) fixed problem - sometimes netinstall did not show new software id;
*) added support for BGP aggregates from IGP routes;
*) user manager - no backup for deleted logs;
Whatâs new in 3.29:
*) fixed problem - local bandwith test could take all the CPU to itself
not allowing other tasks to run;
Whatâs new in 3.28:
*) fixed hotspot problem - on multi-processor systems it was not possible
to set IP address for hotspot client during login - deadlock did happen;
*) fixed hotspot problem - it was possible for hotspot to spike CPU usage
to 100% and not to accept new logins during that time;
*) added ethernet broadcast support for WakeOnLan tool;
*) api - value of âcommentâ property was only returned from âsystemâ package
programs;
*) to see actual values of sensitive configuration parameters (such as
passwords), user needs to possess policy âsensitiveâ;
*) avoid problems with western time zones by always advancing clock on
startup past january 2st 1970, 00:00:00 UTC;
*) added ârun-after-resetâ argument to âreset-configurationâ command. It
allows to specify name of console script file to run after the
configuration reset reboots the router. When this argument is used any
other default configuration scripts are ignored.
*) route - fixed a crash;
*) routing-test - fixed OSPF routing table calculation;
*) send keepalives every 30s (was 3 min) on ppp clients - make some 3G connections
more stable;
*) routing-test - changed BGP network and default-originate behaviour;
*) web proxy - allow to edit error page;
*) console - terminal window size change now does not trigger full terminal
reset;
*) mesh protocol - improved loop prevention (becomes incompatible with earlier versions);
Whatâs new in 3.27:
*) fixed memory leak in DNS;
Whatâs new in 3.26:
*) fixed hotspot problem - deadlock was possible on multi-processor routers;
*) fixed problem - it was possible for RouterBOARD to loose configuration
after upgrade to RouterOS version 3.25;
*) added MetaROUTER support on RB1000;
*) using pptp and eoip tunnels simultaneously could crash router;
*) api - âcommentâ property was not accessible, fixed;
*) console, api - fixed handling of decimal fractions in time interval values;
*) bonding interfaces could sometimes disappear after reboot;
*) changed mesh protocol to send routing packets to broadcast address;
*) automaticly add ppp client interface when GPRS/3G modem is plugged in;
*) added simple/advanced mode to ppp client in WinBox;
*) added support for Huawei E1550 UMTS/HSDPA modem;
*) added support for Cricket Wireless A600 modem;
*) added support for yet another Globetrotter HSDPA modem;
*) added support for Sony-Ericson MD300 modem;
*) added support for ZTE MF626 & MF627 modems;
Whatâs new in 3.25:
*) fixed problems with files under MetaROUTERs;
*) made WinBox work better on smaller screens;
*) made WinBox to not bring down BGP & OSPF when BGP window was opened;
*) WinBox menu is better organized, all sub-menus are sorted;
*) fixed WinBox problem - /128 IPv6 addresses could not be entered
where network address was expected;
*) added l2mtu interface parameter with ability to configure for
interfaces that support it;
*) RB1xx ether1 did not work properly in switch mode;
*) api - do not accept truncated property names;
*) api - closed sessions were not removed from the â/user activeâ list;
*) routing, routing-test - fixed a BGP crash;
*) routing-test - deleted routes were sometimes left displayed in Winbox;
*) routing-test - fixed BGP interoperability issue with old Ciscos;
*) routing-test - added remove-private-as BGP peer config option;
*) added few more variables to hotspot html pages:
bytes-total, bytes-total-nice, packets-total
*) bandwidth-test supports testing over multiple tcp connections (default 20);
*) graphing - HTML page refresh-interval configurable in console;
*) user manager - IP pool added to user batch-add form;
Whatâs new in 3.24:
*) added ability to run non RouterOS in MetaROUTER;
*) improved address-list and layer7 firewall feature support for smp systems;
*) special-login items can now be disabled;
*) fixed special-login to update used-by property of port;
*) fixed USB UPS monitoring on RB433UAH;
*) console - âprintâ command reuses assigned item numbers;
*) fixed issue with Cisco BGP VPLS when used between 2 RouterOS devices;
*) console - âprintâ commands have new option âfollow-onlyâ that continuously
shows changes like the âfollowâ option, but does not print all items
at the beginning;
*) api - âfollowâ and âfollow-onlyâ options of âprintâ commands now work,
â.deadâ property is reported for deleted items;
*) api - âlistenâ command now is alias for âprintâ with âfollow-onlyâ
opriont set;
*) api - several commands running in parallel could produce intermixed
output, fixed;
*) console and api - fixed problem that caused property values sometimes to
incorrectly have value â(unknown)â, this could happen when running
several console or api commands at once;
*) fixed BGP VPLS crash when site-id > 15 used somewhere in network;
*) changed BGP AS path number output format to ASPLAIN;
*) console - new scheduler tasks use trimmed effective user permissions as the
default value of policy, previously default value was âread,write,testâ;
*) added ttl matcher to ipv4 firewall;
*) improved dns cache not to allow other RRs in statically configured domains;
*) fixed vlan on bonding;
*) fixed bonding modes balance-alb and balance-tlb;
*) added per-connection-classifier matcher to firewall;
*) fixed wireless Hw. Fragmentation Threshold in WinBox;
*) user manager - added option to specify custom Return URL
for Authorize.Net payments;
*) user manager - write logs to syslog topic manager,account;
*) routing-test - support for per-VRF BGP instance redistribute settings;
*) routing-test - speed up BGP route processing;
*) routing-test - added routing-table configuration to RIP;
Whatâs new in 3.23:
*) added WakeOnLan tool
*) fixed installation on fresh disks or VMs;
*) add 802.1ad Service Tag support for VLAN;
*) wireless - fix for RTS/CTS when used together with dynamic ACK timeout;
*) serial ports are now grouped per USB device;
*) added gsm info command to ppp-client;
*) added URL support to fetch tool;
*) added dial-on-demand mode to PPTP & L2TP clients;
*) ssh - now non-interactive console commands can reference variables;
*) fixed TFTP server logging;
*) fixed problem - â/system upgradeâ (autoupgrade) did not show proper package
architecture and was unable to fetch new packages;
*) fixed bug - hotspot âwalled garden ipâ rules did not work on some boards
after reboot;
*) added â/interface print statsâ command;
*) improved support for OSPF as PE-CE routing protocol;
*) added OSPF sham links;
*) fixed a bug in set-bgp-prepend-path routing filter;
*) fixed some MPLS TE reoptimize bugs;
*) added MPLS TE bandwidth management features;
*) netwatch - ignore items with interval 0s, this value was causing
netwatch to fail;
*) routing-test - added new type of gateway argument: ip address together with interface;
*) api - âdisabledâ property was not available from api since 3.21, fixed;
*) api - added support for retrieving OID values;
*) api - removed special behaviour of âfindâ command under API. Use
âprintâ command with queries instead of âfindâ. This change fixes
scripts that are started from API and contain âfindâ command.
*) console - removed support for octal numbers, now string of digits with
a leading zero is interpreted as decimal number;
*) console - added binary ~ operator that matches value against
POSIX extended regular expression;
*) console now accepts decimal numbers with k/K M G T P suffixes for
values of some properties;
*) console - fixed export problems:
if long line is wrapped just before space charater, the space character
has to be escaped, otherwise it is lost;
errors during export generated a comment line that was incorrectly enclosed
in quotes;
*) scheduler - added owner and policy properties; all existing
scheduler entries will get owner name â*schedâ and policy
read,write,test;
*) routing-test - allow to specify that route gateway is in the main routing table;
*) added route cache statistics;
*) fixed mesh protocol;
*) graphing - fixed IP address mask display issue for low endian architectures;
Whatâs new in 3.22:
*) added advanced switch features for RB450G;
*) added support for MetaROUTER on RB450G;
*) added support for adding physical interfaces to Metarouters;
*) added set-bgp-prepend-path action to routing filters;
*) added WinBox OSPFv3 support to routing-test package;
*) added WinBox IPv6 routes support to routing-test package;
*) console - added âhide-sensitiveâ option to the export command;
*) user manager - fixed customer remove interface bug;
*) fixed Cisco BGP VPLS autodiscovery in mpls-test package;
*) fixed LDP to not disconnect on unknown capabilities of remote
peer (should help establish LDP session with Junos);
*) fixed ethernet port name reordering on RB493;
*) bonding mode balance-alb now works on RB1xx, RB4xx, RB616, RB600, RB750,
RB1000;
*) added â/interface ethernet print statsâ command for RB450G and RB750;
*) fixed CSPF in routing-test to properly interpret link bandwidth;
*) added support for C-motech CNU-680 CDMA 1x EV-DO 450Mhz USB Modem;
Whatâs new in 3.21:
*) backported MetaROUTER support for RB4xx from v4;
*) added WinBox MPLS & VPLS support mpls-test package;
*) added WinBox BGP support to routing-test package;
*) api - added query support for âprintâ command;
*) added support for bsd-syslog;
*) added TFTP server;
*) added authorization and TLS support to email tool;
*) added pppoe-scanner;
*) added tftp protocol support to fetch tool;
*) fixed ipsec policy priority to work as documented;
*) fixed BGP route selection in routing package;
*) allow to use IPsec aggressive mode with pre-shared keys;
*) fixed some problems in mesh protocol;
*) fixed https proxying with parent proxy;
*) fixed Prism shared IRQ issue;
*) fixed multiple MPLS/VPLS bugs in mpls-test;
*) fixed boot problems on some RB1000s;
*) added /interface mesh traceroute command;
*) fixed web proxy source address selection;
*) fixed pcq queue - pcq sometimes could get through more traffic
than specified in max-limit;
Whatâs new in 3.20:
*) added support for IPsec hardware acceleration on RB1000,
increases IPsec SHA1-3DES encryption from 45Mbps to 500Mbps
and SHA1-AES from 79Mbps to 500Mbps;
*) fixed IPv6 on RB1xx and RB5xx;
*) added support for ZTE MY 39, CDMA EVDO USB card;
*) added clear-df action to firewall;
*) fixed bug - sometimes netinstall could fail to install RouterBOARD
with âERROR: could not format partitionsâ;
*) fixed PCQ bug - pcq-rate < 70000 did not work correctly (broken in 3.17);
*) added radius-mac-format setting in hotspot server profile;
*) allow to use ip firewall for encapsulated PPPoE packets;
*) graphing - fixed 10Gbit card bug;
Whatâs new in 3.19:
*) fixed problem - web proxy used up all router memory
if unlimited ram caching was enabled;
*) fixed problem - some log topics got swapped in configuration;
*) reduced maximum supported memory for RB1000 to 1.5Gb (was 1.75Gb);
*) interface mesh was not working in 3.18, fixed;
*) fixed Prism crash;
*) fixed VPLS interface related crash in mpls-test;
*) allow to enter range in BGP instance confederation peers;
*) console - fixed â/system backup saveâ command, name argument is
optional, and backup file name is automatically generated if empty;
*) sped up IPv6 forwarding on RB4xx, RB1xx and RB5xx;
*) fixed BGP route selection in routing-test;
*) fixed dhcp server to update agent-circuit-id and agent-remote-id for lease
whenever it changes;
Whatâs new in 3.18:
*) IPv6 address auto-configuration: added recursive DNS server option;
*) fixed problem - sometimes firewall did not work after reboot on RB1xx;
*) do not send IPv6 packets over PPTP, L2TP or PPPoE - could confuse some
servers or clients;
*) allow queues to have all traffic, not only ip (for example vpn);
*) added ability to specify dns name in bandwidth test in WinBox;
*) fixed problem - sometimes RB1xx (and RB4xx) could not start up or startup was very long;
*) improved ipv6 sniffing;
*) improve torch and sniffer behavior under high load;
*) improved queue statistics;
*) fix xen make-routeros-image command;
*) fix potential wireless crash under load when negotiating encryption;
*) fix several MPLS issues in mpls-test;
*) fixed support for Novatel Wireless Ovation MC950D HSUPA;
*) fixed some bugs in routing-test OSPF;
*) added support for D-Link DUB-E100 USB Ethernet adapter;
*) fixed user-manager database rebuild command to succeed in case of
malformed database disk image;
*) sms - added descriptions for error codes;
*) sms - added automatic âsmscâ (service centre address) value detection,
to work around first time error when sending SMS without specifying
an âsmscâ value;
*) fixed - during uptime 4:20 .. 5:00 interface traffic (byte and packet
count) was being reported 100 times larger than the actual value;
*) provide L2TP server address in Called-Station-Id when doing authentication over RADIUS;
*) added support for Sierra Wireless MC8790;
*) recalibrated noise floor adjustment for R5H;
*) updated drivers & kernel - fixed fast clock issue on x86;
Whatâs new in 3.17:
*) added support for Intel 10Gb PCI Express driver;
*) made Huawei E220 USB modem work again;
*) added support for Novatel Wireless Ovation MC950D HSUPA;
*) fixed PCQ fairness when pcq-total-limit is reached;
*) fixed fetch tool to work when dst-path is not specified (broken in 3.16);
*) fetch tool - added keep-result command line argument;
*) allow to specify routing-table for ping, trace-route, and telnet;
*) fixed an IPsec bug;
*) fixed /ip firewall address-list;
*) added propagate-ttl option for MPLS;
*) fix very long wireless scan-list issues;
*) fixed problem - sometimes PCQ could stop data pass-through if pcq-rate was set;
*) fixed problem - L2TP could stop working when one of clients stopped responding
at wrong time;
*) fixed problem - reduced size of supout.rif files;
*) graphing - support for 10 Gbit interfaces;
*) routing-test - added support for multi-instance OSPF;
*) user manager - fixed bug for PayPal payments with long parameter list;
*) user manager - database load command supports external storage
for temporary files;
*) user manager - added support for all UTC time-zone offsets,
including +5:30, +5:45, etc.;
Whatâs new in 3.16:
*) added support for IGMP proxy;
*) improved Nstreme polling in wireless-test;
*) routing-test - routing filters now use regular expressions
to match BGP AS_PATH; use â_â (underscore) to match any of:
comma, space, beginning of line, end of line, parentheses, braces;
*) make secondary disk contents visible under /file;
*) console - allow use of â/â and â.â characters in backup, export
and print output file names;
*) fixed bug - hotspot universal client did not work for clients
with IP address ending with 127 or with 224-239;
*) fixed problem - x86 clock was 10 times faster then it should be on some boards;
*) fixed kernel panic on RB1000;
*) console - fixed wrapping of long lines in GNOME Terminal;
*) console - autodetect Mac OS X Leopard Terminal.app, fixes condition
when only the bottom line of the terminal was used;
*) console - âfindâ commands could not match some properties, like
ârouting-markâ of the â/ip route findâ command. Fixed;
Whatâs new in 3.15:
*) added workaround for non-standards compliant CPE with timestamp issue;
*) added ability to manage multiple disks & stores under /store;
*) added support for storing user-manager database on secondary media via /store;
*) /store should be used to set up secondary disk as web proxy cache;
*) added support for Mesh in WinBox;
*) fixed client roaming in mesh protocol;
*) fixed bug in MME routing protocol:
routes sometimes were lost from routing table;
*) fixed some bugs in routing-test;
*) fixed traffic forwarding when VRF (virtual routing and forwarding) is used;
*) fixed problem - USB did not work on Geode LX boards;
*) fixed problem - farsync cards did not negotiate links;
*) added support for Novatel EU870D;
*) added support for Intel 82575EB & 8257GB gigabit ethernet PCI-Express cards;
*) removed support for all synchronous cards but farsync;
*) graphing - all target (source) addresses displayed in queue statistics page;
*) bridge firewall broute table is removed - it did not work as expected anyway;
*) ingress-priority matcher added to bridge firewall
*) fixed use-dns property of console traceroute command, default now is
use-dns=no;
*) updated UK 5.8 FIXED regulatory domain info;
*) /system ssh now by default uses name of logged in user instead of âadminâ;
*) fixed support for some microSD cards on RB400;
*) include Relay-Session-ID in packets sent by PPPoE client if required;
*) added ability to specify src. address for radius client;
*) dns cache - improved static entry behavior;
*) fixed dial-on-demand on ppp interfaces;
Whatâs new in 3.14:
*) fixed â/xen consoleâ command;
*) fixed problem - queue bursts did not work;
*) added support for OSPF NSSA in routing-test;
Whatâs new in 3.14rc1:
*) updated drivers, some of the changes:
synchronous cards should work in frame relay mode;
SIP connection tracking is more standards conformant;
valid TCP connection packets will not be marked as invalid;
*) mlppp - fixed problem when small packets could not be transmited
while more than 2 links were active;
*) bgp - fixed attribute flags checking;
*) fixed dhcp client - routes were not added back after lease expires
and then is acquired again;
*) fixed handling of multiple identical address-list entries
*) ospf could become unresponsive in some situations, fixed;
*) winbox - fixed problem: when moving multiple items at once,
correct order was not maintained;
*) fixed automatic fan control on RB600;
*) added ipv6 firewall address-list;
*) fixed some bugs in mesh protocol driver;
*) fetch tool - added basic HTTP authentication;
*) 6to4 tunnel - allow to specify remote address;
Whatâs new in 3.13:
*) hotspot - fixed dst-nat for SMTP (broken in 3.11);
*) dhcp client - added support for DHCP option 121 (classless route);
*) fixed simple queues - changing simple queues could lock up i386 routers
*) routing-test - added support for multiple recursive nexthops;
*) routing-test - fixed BGP AS number byteorder, broken in 3.12;
Whatâs new in 3.12:
*) fixed problem - static queues on PPPoE, PPTP, L2TP interfaces became invalid
on client reconnect;
*) changed behaviour of simple queues - queues with no limit and type default-small
and no children actually do not get installed, as if there was no queue;
*) console - allow â{}â array syntax only for some command arguments, as it
does not make sense in most cases and interferes with the existing
scripts. Now â/system script add source={âŚ}â works as it did
before 3.11;
*) graphing - fixed crash when dynamic interfaces/queues disappear;
*) fixed IPv6 address auto-configuration on routerboards;
*) added support for OSPFv3;
*) improved PCQ queueing algorithm;
*) dhcp server - pass Agent-Remote-Id and Agent-Circuit-Id to Radius server;
*) user manager - option to use test gateway for Authorize.Net payments;
*) fixed bug - web server could lock up at startup
(no access to hotspot login page after that);
*) routing-test - added support for 4-octet BGP AS numbers;
*) routing-test - added default-originate feature for BGP peers;
*) routing-test - added IPv6 BGP networks and aggregates;
Whatâs new in 3.11:
*) fixed bug - in some cases web proxy https with parent-proxy did not work;
*) added default-route-distance setting for DHCP client;
*) mesh protocol - bridge interface in a mesh did not work well, fixed;
*) multicast - fixed bootstrap router (BSR) mechanism;
*) user manager - users can now be redirected to HotSpot login page after
PayPal payment;
*) added ability to dst. nat only address or port, not both at the same time;
*) ospf - fixed default route;
*) ipsec - fixed tunnel mode with dynamically generated policy;
*) port remote-access - fixed allowed-addresses check;
*) ethernet half duplex modes on rb400 series work now;
*) console - fixed entering of IPv6 prefixes;
*) console - fixed crash on window size change;
*) console - bit operations (& ^ | << >>) now work with numbers, too;
*) console - brace syntax for array declarations ( { value ; value ; value } )
now can be used also where () expressions can be used, previously
worked only inside the expressions. Example:
:foreach i in {1;2;3;4} do={:put $i}
*) console - inside expressions â,â operator can be used to concatenate arrays,
unlike â.â which works with strings. Arguments that are not arrays are
treated like arrays with single element. Example:
{1,2,3;4,5,6;7,8,9} produces value {{1;2;3};{4;5;6};{7;8;9}}
(1,{2},{{3;4}},5,{},{6,7},8) produces value {1;2;{3;4};5;{6;7},8}
*) console - âmoveâ commands no allow list of source items to be empty and
to contain duplicate items. The porpose is to simplify scripts that use
âfindâ commands to move items. Example:
move ([find dynamic],[find inactive]) - moves all âdynamicâ and
âinactiveâ items to the end of the list, does not raise error if
any item is both âdynamicâ and âinactiveâ, or if there are no items;
*) console - âmoveâ command does not update item numbers anymore;
Whatâs new in 3.10:
*) added Multilink PPP to PPPoE client - just specify multiple interfaces
to enable it;
*) added ability to add dynamicly PPTP, L2TP & PPPoE client addresses
to firewall address-list, specified in ppp profile,
or via RADIUS in Mikrotik:19;
*) added address-list attribute support in user-manager;
*) added fan control for RB433;
*) added voltage monitor for RB433AH;
*) console:
fixed âinterface wireless print detailâ, now shows the same output as
âinterface wireless print basicâ;
fixed print to file, now writes complete contents, fixed resource leak;
show name of running scripts in â/system script jobâ, update
âlast-startedâ value;
could not use item names for â/interface ovpn-serverâ and
â/interface ovpn-clientâ, fixed;
fixed problems with export:
some settings were not included in full export, such as
â/interface wireless nstremeâ);
some settings had duplicate entries with an error, such as
â/system ntp clientâ when ntp package was enabled;
long parameter values were incorrectly split across multiple lines;
export now quotes all values that are split across multiple lines, it
also adds line split before all newline characters, which improves
readability of exported script sources;
*) api - some properties were included multiple times in getall responses;
*) port - properly tag all inactive ports;
*) port - fixed memory leak that was triggered by addition/removal of
USB serial ports;
*) changed post-boot critical log messages - write a separate log entry
explainig the cause of an non-administrative reboot, such as watchdog
ping timeout, even if system rebooted cleanly;
*) fixed user-manager âdatabase rebuildâ command to correct database errors;
*) fixed bug - user-manager customer password was not decoded
correctly when database backup was transferred
between Intel/RB100/RB500 and RB300/RB400/RB600/RB1000;
*) fixed bug - â/blinkâ command did not work on RB300/RB600/RB1000;
*) allow to configure OSPF authentication key ID;
*) allow to include bridge interface in a mesh interface;
*) ipsec - added Dead Peer Detection;
*) fixed some random crashes on RB411 & RB433;
*) fixed bug - OpenVPN could corrupt data on high load and force other end to disconnect;
*) fixed bug - DHCP server did not return DHCP options in response to
DHCPINFORM request;
Whatâs new in 3.9:
*) bridge could make router busy even without traffic;
*) fixed route redistribution in RIP (bug introduced in 3.
*) fixed AR5212 kernel crash on setting change;
Whatâs new in 3.8:
*) fix B mode rate reporting for Atheros 5211 cards;
*) IPv4-compatible addresses as IPv6 route gateways now require
manually specified interface;
*) fixed removing external routes from OSPF;
*) added initial version of layer-2 mesh routing protocol;
*) fixed problem - OVPN server sometimes crashed;
*) fixed problem - torch could fail to aggregate connection data;
*) fixed problem - RB500 on high ethernet load rebooted sometimes;
*) fixed problem - if PPP (ISDN) client requested itâs own address, then server
did not report it in logs correctly;
*) fixed problem - if PPP (ISDN) client has itâs own address, it was
not used allways as on-demand ip address;
*) fixed problem - PPPoE, PPTP & L2TP stops receiving packets, if
MRRU is set and multiple packets get lost;
*) added support for Intel Gigabit PCI-Express cards;
*) fixed problem - RB433 did not work with v3.7;
Whatâs new in 3.7:
*) improved simple queue list updating;
*) fixed p2p edonkey protocol matcher on rb600;
*) fixed booting on CR;
*) fixed problem - CF did not work on routerboards;
*) fixed ping to 2001::1 like IPv6 addresses in console;
*) made ISDN work again;
Whatâs new in 3.6:
*) fixed booting for x86;
*) initial support for MPLS Traffic Engineering tunnels;
*) added support for ZTE AC8700 USB modem;
Whatâs new in 3.5:
*) updated drivers;
*) user manager - fixed bug when PayPal payments were discarded
because of uppercase characters in business-id field;
*) fixed bug - could not ping ip address with 12 digits (like 123.123.12.12)
in console;
*) console - changed behaviour of â.â operator when one or both of operands
is an array, now it produces an array with all pairwise concatenated
elements of left and right arrays. An example:
if $A contains array 1,2,3,4, then
:foreach i in=â10.$A.$A.0/24â do={:put $i} will print 16 network prefixes.
Currently behaviour of â.â operator with an empty array value is
undefined.
*) console - fixed bug introduced in 3.4. Concatenation of strings
yielded array, so (âAâ . âAâ) was A;A, now (âAâ . âAâ) results in âAAâ,
as before;
*) fixed web-proxy check drive command on routerboards;
*) console - fixed column widths;
*) console - fixed memory leak in âfindâ command, introduced in last version;
Whatâs new in 3.4:
*) improve transmit lockup detection to work around issues with few wireless
clients;
*) fixed bug - RB100/RB500 upgrade from RouterOS v2.9 could fail if
version 2.9 was installed by netinstall from v3;
*) console - compatibility syntax for âfindâ and âprint whereâ expressions.
If = or != operation has as the left operand name of item property, without
leading â$â, then right hand operand is parsed according to the syntax
of that propery. This also adds back command line completions. Example:
/ip address print where interface=ether1
ether1 was parsed as a reference to variable âether1â, now it is parsed as
name of the interface, like in version 2.9;
*) backup - proceed on read errors, log errors with topics âbackup, criticalâ;
*) console - allow commands like âmonitorâ and â/tool fetchâ in scheduler
scripts;
*) web proxy - when src-address is specified, use it for outgoing connections;
*) fixed crash in pppoe, pptp & l2tp when using ip pools with radius server;
*) added support for Option Fusion UMTS Quad-GPRS (Vodafone Globetrotter);
*) fixed VLAN on wireless not running after reboot issue;
Whatâs new in 3.3:
*) fixed SNMP DoS bug
*) fixed bug - PPPoE server could crash when running on multiple cores;
*) fixed bug - bridging over PPP interfaces with encryption enabled did not work;
*) fixed dhcp server - arp entries were not added after reboot;
*) fixed problem in pppoe, pptp & l2tp - server could restart;
*) fixed bug in console - bridge and ip filter âprint staticâ and âprint
dynamicâ commands had the opposite effect;
*) fixed bug - DHCP server did not parse Relay-Agent-Info option 82;
*) fixed bug - hotspot login could fail with âippool acquire failedâ;
*) graphing - ip address formatting bugfix;
*) ospf - added support for Opaque LSA;
*) ospf - fixed routes changing type from Intra Area to AS External;
*) ospf - fixed multicast group membership in case there are
multiple IP networks configured on a single interface;
*) routing - now iBGP routes are resolved through IGP and static by default;
*) user manager - fixed ampersand bug;
*) updated regulatory information for Australia;
*) updated drivers;
Whatâs new in 3.2:
*) ssh - use preshared key also when user name has login parameters;
*) added â:led user-led=[yes|no]â command for RB300/RB600 series;
*) graphing - bugfixes; health section restored;
*) fixed problem - /ip traffic-flow could crash router
*) fixed simple queue vlan matching
*) fixed ipv6 firewall counters
*) user manager - fixed bug related to download/upload counter overflow
in reports;
*) fixed problem - sometimes dhcp client could not renew lease
on wireless interface;
*) fixed problem - connection tracking entries could not be removed sometimes;
*) ospf - donât install AS external routes with local address as gateway;
*) ospf - fixed bug triggered by adding and removing same AS external route
on two routers; that route could always remain in OSPF routing table;
*) web proxy - compact flash and USB disks did not show up after reboot
on slow boards, fixed;
*) fixed wireless transmit lockup detection;
Whatâs new in 3.1:
*) fixed wireless reassociation issue;
*) added support for Novatel Wireless Merlin XU870;
*) added support for nForce Ethernet cards;
*) fixed problem - user manager database in-use counter was wrong
for database size over 21 MB;
*) console - fixed parsing of alphabetical operators (âandâ, âorâ, âinâ) in
expression context, this also fixes default configuration revert script;
*) fixed TKIP on RB300 and RB600;
*) fixed ipv6 firewall connection-state matcher;
*) improved WinBox connection speed & memory usage;
*) report correct tcp-state for firewall connections;
*) fixed ppp user names in ip accounting;
*) fixed via vt6122 (rb600 ether3) driver: multicast packet receiving
did not work properly;
*) user manager - voucher template supports kb/mb/gb for
download/upload/transfer limit values;
*) added â:led user-led=[yes|no]â command for RB100/RB400/RB500 series;
Whatâs new in 3.0:
*) fixed auto upgrade on RB333 & RB600;
*) made RB411 bootup more stable;
*) made DNS & WINS setting work again in PPP;
*) fixed bug - dhcp client did not update NTP server list;
Whatâs new in 3.0rc14:
*) fixed locking up in PPPoE server;
*) fixed bridging in PPTP, L2TP an PPPoE;
*) fixed bug - MPPE encryption keys received from RADIUS server were decoded
improperly on RB333;
*) added support for BGP signalled VPLS;
*) fixed bug in port remote-access - it was inserting random data, mostly
nulls, in data sent to serial port and to tcp connection;
*) fixed bug in console error propagation, code like the example below caused
console to enter busy loop:
:do { badcommandname; } while=(true);
*) fixed hotspot https walled-garden;
*) fixed bug - dhcp server failed to give out options with code > 127;
*) console - fixed numeric parameters that accept negative values, were broken
in rc12;
*) fixed port line-state values on MIPS RouterBoards;
*) fixed bug - idle-timeout & session-timeout were not disabled if they
were unset in ppp profiles;
*) fixed OSPF compatibility bug with v2.9 (and some other vendor
implementations): LS Acknowledgments were sent to wrong address;
*) fixed Broadcast flag for DHCP on RB300/RB600;
*) fix wireless nstreme packing problem;
*) improved layer7 firewall matcher memory usage;
*) console - do not add input to history if it is the same as previous line;
*) fixed bridge to forward (R)STP frames as regular if (R)STP not enabled;
*) fixed bug - configuration for missing serial ports was not tagged inactive;
*) console - fixed safe mode, it was causing wery high cpu usage and terminal
traffic;
*) console - added login parameters, passed as part of login name, after â+â;
can be used to disable colors (+c) and terminal autodetection (+t), e.g.
âadmin+ctâ;
*) fixed problem - bandwidth shaping on ARES traffic was not working properly;
*) user manager - fixed security bug in user page;
*) dns resolver has configurable max UDP packet size;
*) fixed dns resolver - tcp queries were broken without ipv6 package;
*) added ingress priority matcher to firewall rules;
*) added number of active pcq queues to queue stats;
*) made advanced mode for wireless interface configuration in WinBox;
Whatâs new in 3.0rc13:
*) fixed problem - clean install on x86 & adding new ethernet interfaces on x86
did not work (introduced in 3.0rc12);
Whatâs new in 3.0rc12:
*) added support for MPLS & VPLS;
*) added ability to specify & disable winbox port under â/ip servicesâ;
*) fixed bug - DFS was not taking into account channel usage when
selecting channel;
*) fixed bug - simultaneously monitoring wireless interface and changing
settings could cause crash;
*) improved memory usage under RB133C;
*) fixed bug - MAC Winbox connection was not very stable;
*) fixed bug in graphing;
*) fixed problem - routerboard sometimes did not upgrade & reboot
if serial cable was not plugged in;
*) interface routing now works with PPPoE âdial-on-demandâ interfaces;
*) fixed dial-on-demand;
*) routing - fixed âset-in-nexthopâ filter (broken in 3.0rc7);
*) implemented more registered client flushing on access-list and
connect-list changes - now connect-list changes disconnect
affected APs, wildcard mac address entry changes disconnect all
clients;
*) fixed bug - Windows could not synchronize to NTP server if local
clock was used as time source (changed stratum from 6 to 4);
Whatâs new in 3.0rc11:
*) added filters to WinBox lists, and added ability to filter routes
without downloading all of them to the client;
*) updated WinBox Loader to v2.2.12 - clicking on IP address in
router discovery list selects ip address not mac address;
*) added â/tool sms sendâ in advanced-tools package;
*) fixed problem - PPPoE, PPTP, L2TP could restart if user disconnected
at wrong time;
*) fixed problem - PPPoE, PPTP, L2TP static server interfaces
disappeared after disconnect;
*) added support for adding OVPN interfaces to bridge through specifying
bridge in ppp profile;
*) multicast - fixed IGMP Leave message handling;
*) nand improvement for RB532A;
*) fixed user-manager database restore from backup for RB500;
*) fixed bonding - when bonding iface was put in bridge arp link monitoring
Whatâs new in 3.0rc10:
*) fixed problem - sometimes PPTP, L2TP, PPPoE and OpenVPN connections
were not accounted properly, and no new connections could be established;
*) fixed problem - L2TP sometimes could not establish connections through
firewall or with Windows;
*) bgp - fixed TCP MD5 authentication on RB300;
*) fixed bug - route did not work with Level 1 license and routing package enabled;
*) api - â/quitâ command now immediately terminates session;
*) console:
âandâ operator in expressions that follow âfindâ and âprint whereâ
now is optional, pre-rc9 syntax âfind mtu=1480 type=etherâ works
as it used to;
added back filters to firewall print commands, filtering by chain
now is âprint chain=inputâ instead of âprint inputâ;
fixed âprint count-onlyâ, it was ignoring any additional âprintâ arguments
that selected only part of items;
Whatâs new in 3.0rc9:
*) fix for rb100 - can change ethernet settings when interface in bridge/bond;
*) fixed problem - RouterOS did not boot on some routers
(reported disk not found);
*) fixed dns resolver - sometimes could not parse packets with AAAA records;
*) hide ppp interface & wireless passwords and keys in WinBox as well;
*) fixed traffic-flow - could hang multi cpu router and ignore targets sometimes;
*) fixed rb100 - ethernets could be set at random bandwidth limit after reboot;
*) console:
repaint whole screen after terminal size change while in editor
(same as pressing F5 or Ctrl-L). this solves numerous issues with
terminal resizing;
added more workarounds for the case when terminal is too narrow
(<4 characters);
now logical operators â&&â and â||â can also be written as âandâ and âorâ;
removed âwhereâ and âfromâ arguments of find command. now find command
can be followed by arbitrary expression that can use item properties,
e.g. âfind dst-address in 192.168.0.0/16 and interface=wlan1â;
added âwhereâ argument to print command. âprint where â and
âprint from=[find ]â are equal;
removed filters from firewall print commands, now write, e.g.,
â/ip firewall filter print where !dynamicâ instead of
â/ip firewall filter print staticâ;
*) web proxy: fixed crash on stopping proxy;
Whatâs new in 3.0rc8:
*) fixed problem - console did not accept ip address ranges correctly;
*) user manager - fixed problem with accounting creating too many sessions;
*) console:
added ip-prefix and ip6-prefix datatypes, written in address/mask
notation;
INCOMPATIBLE CHANGE: expressions of the form â(123/45)â (where first
operand is literal unquoted value) currently will be parsed as single
string, to write division put space before â/â (like with â.â operator);
added operator âinâ that checks if first argument is inside second
argument, currenty implemented for the case where second argument is
ip-prefix or ip6-prefix and first argument is either address or
another prefix;
donât perform full reset of terminal on login;
fixed terminal capability detection, now windows telnet client
works better. TERM environment variable is ignored completely now,
it was overriding detected values before;
*) added support for Huawei E220 USB modem;
Whatâs new in 3.0rc7:
*) ftpd - automatically reboot after finishing upload that has name *.auto.npk;
*) added support for Sierra Wireless AirCard 595U;
*) ping - show more types of ICMP reply messages, like in 2.9 versions;
*) add ICMP MPLS extension support to traceroute;
*) console detects terminal size and capabilities, TERM environment
variable is not used, so now this works even over serial;
*) console - fixed crash on non-ASCII characters in input and output;
*) console - export correctly strings that contain control characters;
*) fixed in console - when argument value evaluation produces error, report
that error instead of âinvalid value for âŚâ message;
*) console - changed the way how required command arguments are processed,
now commands like âenable [find]â donât fail with error when find returns
nothing;
*) fixed memory leak on RB500;
*) fixed layer7 protocol matcher, did not handle \x.. sequences correctly;
*) fixed allow-shared-key mode for wireless;
*) fixed station-pseudobridge mode when used in combination with
nstreme framer-policy;
*) fixed hidden ssid issues with wds links;
*) SNTP client - adjust DST according to timezone settings when clock changes;
*) console - fixed crash when terminal size is extremely small (like 1x1),
assume default width 80 if terminal is too narrow;
*) SNTP - fixed overflow bug, now clocks are adjusted correctly if initial
time is way back (like jan/01/1970 on routerboards);
*) added RIPng support in WinBox;
*) added BGP for IPv6 support in WinBox;
*) added PIM support in WinBox;
*) added hide passwords option to WinBox;
*) added regular expression matching to dns resolver static entries;
*) user manager - fixed bug for credit extension using PayPal payments;
Whatâs new in 3.0rc6:
*) RIP - fixed some problems;
*) RIP - automatically distribute connected routes
falling within range of some configured network;
*) RIPng - network configuration statements removed,
interface configuration now is mandatory;
*) added support for IPv6 Firewall in WinBox;
*) added support for IPv6 DNS cache in WinBox;
*) added support for MME routing protocol in WinBox;
*) added support for L7 matcher in WinBox;
*) added support for Prolific 2303 based USB serial devices;
*) specify tcp-mss in dynamicly added PPP mangle rules & do not add
them when mtu is bigger then 1500;
*) fixed USB UPS detection;
*) fixed bug - PPTP client did not work with Windows PPTP server;
*) limited number of active authentication sessions for PPPoE server
to not overload RADIUS server;
*) fixed bug - ssh command did not work on RB333;
*) added support for Intel EXPI9404PT PCI-E ethernet adpater;
*) added simple SNTP client to system package
& removed regular ntp from bundle package;
*) updated timezone information;
Whatâs new in 3.0rc5:
*) added layer7 protocol matching capability in firewall;
*) updated network drivers;
*) make external-fdb for station-wds interfaces be disabled when
in auto mode;
*) added regulatory domain info for 5.8GHz band in Germany;
*) rip - fixed netmask for default route;
*) added /system default-configuration;
*) ability to reset without applying default configuration;
*) reverted BGP network behaviour back to version 2.9;
*) fixed BCP;
*) fixed PPPoE, PPTP, L2TP problems with remote authentication;
*) made Multi-Link over single link work properly in PPTP & L2TP;
*) improved ares/warez p2p protocol matching
*) ospf - fixed MD5 authentication;
*) console - fixed memory leak in âfindâ command;
*) fixed ip accounting;
*) user manager - customers can configure Authorize.Net title shown to users;
Whatâs new in 3.0rc4:
*) fixed bug - OpenVPN key renegotiation did not work;
*) updated 5ghz regulatory information for Romania, South Africa and Ireland;
*) added support for dynamic bridge port adding and path cost update for
station-wds mode;
*) fixed rb500 korina driver (ether1) transmit issue;
*) improved wireless performance (also with 2.9);
*) improved nstreme2 performance;
Whatâs new in 3.0rc3:
*) user manager - added PayPal options (https-response & accept-pending);
*) user manager - added transfer-limit to user batch-add form;
*) user manager - added download, upload and total transfer to CSV;
*) added 5GHz turbo band for Germany and Italy;
*) added âhostâ argument to âfetchâ tool to support virtual hosts;
*) fixed handling of power saving wireless clients;
*) ftpd - automatically execute uploaded scripts that have name *.auto.rsc;
*) fixed bug - BCP could not be negotiated with some Ciscoâs;
*) fixed bug - PPTP & L2TP did not work on RB333;
Whatâs new in 3.0rc2:
*) added RFC 2217 server (configure under â/port remote-accessâ);
*) renamed âgetâ tool to âfetchâ, avoids confusion with builtin âgetâ commands;
*) ospf - added âpassiveâ interface flag;
*) ups - fixed duplicate logging of line power state;
*) fixed bios upgrade from RouterOS on RB200;
*) added switch support for rb1xx;
*) added support for ipv6 firewall;
*) added ipv6 support to dns cache;
New features commentary:
*) installation and boot of USB sticks/drives with RouterOS
Netinstall can now install RouterOS on USB drives. Minitowers
and rackmounts with biosâs that support USB boot can now easily boot
from USB flash/hard drives. The USB flash sticks are available in
most electronics stores and are a suitable replacement from IDE
flashdrives and CF with IDE adaptors. It might be advisable to find
a secure place to connect the USB stick so that it canât be knocked
off easily. As of v3rc2,there is one problem that you should not
have a hard drive with RouterOS in the same system or the boot
program on the USB drive will find the hard drive with RouterOS and
probably boot that instead of the RouterOS on the USB stick â we
will work on fixing this.
*) RFC 2217 serial server TCP to serial
Now you can set the serial port to RFC 2217 server mode and
you can use a remote application to communicate/control the serial device.
Find out more about this protocol at http://www.faqs.org/rfcs/rfc2217.html
Whatâs new in 3.0rc1:
*) enable routing package on upgrade - to fix upgrade from 2.9 version
where routing-test package was used;
*) console - parser now accepts newlines as CR, LF, CR+LF, this fixes import;
*) user manager - using +/- image for group field show/hide instead of
confusing checkbox;
*) fixed bug - usb devices did not work;
*) console - added tab key completions in editor;
*) fixed slowness of RB112/RB133C during bootup (introduced in 3.0beta9);
*) console - fixed variable name lookup;
*) console - added back â/setupâ command;
*) console - added â/system script environmentâ;
*) console - fixed wireless interface configuration export;
*) integrated MAC Ping in to regular Ping in WinBox;
*) added support for Marvell IDE controller that is embeded in new Intel motherboards;
*) fixed bug - for routes received via RIP nexthop was invalid in some cases;
*) added âgetâ tool for downloading files to router via HTTP or FTP;
*) console - some properties could not be set via API, fixed;
*) user manager - fixed bug for PayPal payments with user data containing
specific characters;
*) ip proxy - setting parent proxy did not work;
*) fixed bug - dst-active was not updated after time update by NTP;
*) console:
fixed âdoâ arguments in â/tool bandwidth-testâ and other
commands;
inside expressions variables can be referenced without putting
â$â before variable name;
âfindâ commands have new argument âwhereâ that allows to write
filtering condition as console expression;
when entering commands from prompt, global variables can be used without
declaring them;
Whatâs new in 3.0beta10:
*) ip proxy - fixed crash; fixed HTTP POST method handling;
*) fixed PCMCIA (non CARDBUS mode);
*) fixed ethernet packet accounting (FCS 4 bytes were not included);
*) ospf - fixed external and inter-area routes;
*) ospf - after Dijkstraâs algorithm was executed 256 times,
intra-area routes become invalid;
*) made Torch to not exlcude non TCP & UDP traffic if no specific port was provided;
*) user manager - added download/upload limit and group fields to batch-add form;
*) updated Realtek 8169 driver;
*) added support for radius-mac-authentication result caching in wireless;
*) fixed SIP connection tracking on RB100 & RB500;
*) added support for Novatel Wireless V740 Verizon;
*) wireless - added configuration option for hardware retries count and
frame transmit lifetime;
*) fixed support for MTB-134 / Portwell EZIO LCD display;
*) added initial IPv6 support;
*) added radius client to send Accounting-On packet on startup;
*) added initial calea support;
*) added ethernet bridging support to PPP, PPTP, L2TP & PPPoE;
*) added MRRU support to PPP, PPTP, L2TP & PPPoE - packets bigger than MTU
can be forwarded;
*) user-manager - 3-byte char (UTF-8) bugfix;
Whatâs new in 3.0beta9:
*) console - removed undocumented scripting commands;
*) console - variable lookup now is done while parsing script:
variable name completion works
variables must be declared before use;
*) some of the fixes mentioned under v3.0beta8, did not got in v3.0beta8,
they are fixed now;
Whatâs new in 3.0beta8:
*) use less memory - makes RB133C & RB112 work better;
*) added initial support for OpenVPN (client & server mode);
*) added support for Sierra Aircard 595 & other Sierra Wireless cards;
*) ipsec - fixed tunnel mode;
*) fixed bug - bridging with bandwidth shaping could freeze whole system;
*) ip proxy - allow setting invalid parent-proxy-port value 0 in console.
this fixes import of default settings;
*) ip proxy - fixed bugs introduced in 3.0beta6 (proxy could crash,
cache was not working correctly);
*) support for full frequency list of Atheros chips;
*) ups - fixed: program was becoming unresponsive when serial ups was
configured but was not connected;
*) user manager - password not revealed on sign-up;
*) console - each user has separate set of global variables;
*) console - fixed crashes when exporting â/system healthâ on non-routerboards;
*) console - removed unexpected entries from export (like /file);
*) policy routing - fixed automatically added rules;
Whatâs new in 3.0beta7:
*) certificates - sometimes when importing CA certificate, certificate
cache was reset. Fixed;
*) fixed RB200 bios upgrade from RouterOS;
*) added reset-configuration command for wireless;
*) user manager - user signup bugfix;
*) fixed RouterOS configuration to reset when âSoft Resetâ jumper on
RB133C or JP1 on RB532r5 is shorted;
*) hotspot - added to retry mac authentication in case of radius timeout;
*) hotspot - added total (in + out) byte limit;
*) fixed wireless sniffer file format;
*) work around bugs in some WPA2 implementations that do not do
proper group key updates;
*) routing - added set-in-nexthop and set-out-nexthop filters;
*) routing - added notification when filters are changed for
RIP and OSPF (affects redistributed routes)
*) routing - added MME routing protocol;
*) user manager - added total transfer (download + upload) byte limit;
*) WMM support;
*) TOS matcher in firewall is replaced with DSCP;
Whatâs new in 3.0beta6:
*) WinBox has ability to search in Tables;
*) RSTP bridge package is now merged in to system package;
*) routing-test package is renamed to routing;
*) console - fixed ââ to have type str;
*) console - reverted change to export script sources in â{}â braces, such
export was not 100% reversible;
*) hotspot - added option to specify any password for mac authentication;
*) added support for interface routes (without nexthop);
*) route deletion from route table now is much faster (important for
full feed BGP);
*) added update-source option for BGP;
*) RIP is rewritten; added passive-interface option for RIP;
*) added /routing prefix-lists; they can be used for RIP filtering;
*) webproxy now supports SATA disks;
*) fixed bug - OS could not be installed on SATA disks without license;
*) added support for more network cards based on RTL8169 chip;
*) console - F5 or ^L key in commandline resets terminal and prints current
input buffer (if it does not fit in one line);
*) console - fixed backslash whitespace sequence inside quoted string
to expand to nothing, as in 2.9;
*) console - fixed completions and help while editing multiline commands;
*) console - prompt for continuation lines now shows open braces and quotes;
*) console - added âas-valueâ option to print and monitor commands that
suppresses normal output and returns array of properties instead;
*) console - âgetâ command without âvalue-nameâ returns array with all
item properties;
*) console - fixed crash in fullscreen editor when adding empty at the end;
*) console - readded 2.9 style help;
*) made WRAP board rebooting work;
*) user manager - added Authorize.Net payments;
*) user manager - prices now stored as decimals;
*) user manager - increased active session count limit for license levels 4 and 5;
*) user manager - object removal confirmation;
*) user manager - CSV files now have header;
*) user manager - popup-blocker workaround for CSV;
*) user manager - close option for active sessions;
*) user manager - reset-counters option for routers;
*) user manager - public-host field for customers;
*) user manager - group field for users;
*) user manager - fixed time-zone bug;
*) user manager - added PayPal payments;
*) user manager - utf-8 handling bugfix;
*) user manager - voucher customization;
*) new vrrp implementation
*) graphing - incorrect scale legend bugfix for large data amounts;
Whatâs new in v3.0beta5:
*) console - fixed prompt for continuation lines to be "⌠";
*) e-mail - changed to send address-literal instead of hostname in EHLO;
*) e-mail - added e-mail,debug and e-mail,warning log topics, errors now go to
system,e-mail,error;
*) console - fixed âgetâ commands, were not reporting flag values;
*) console - removed :list command;
*) console - multiline command editing:
Ctrl-\ splits line,
prompt shows current line number and total number of lines
when more than one,
home/end twice goes to beginning/end of command like in
fullscreen editor;
console - edit command works also in single line input mode;
console - âsourceâ argument in â/system scriptâ and âdoâ arguments in
various monitor commands accept scripts written in â{}â braces. export
uses this syntax to output scripts;
Whatâs new in v3.0beta4:
*) added GIS/WISPr xml pages for hotspot smart client support;
*) console - order export items by dependencies.
*) fix virtual-AP default mac address;
*) fixed Atheros receive stalling bug that could be observed while
snooping and frequency-monitoring;
*) fixed interface disappear issue on bridge port disabling/removing;
*) fixed station-pseudobridge to not use local macaddress as
default for translation;
*) made ip firewall not be used for bridged packets by default;
Whatâs new in v3.0beta3:
*) added Event-Timestamp radius attribute in hotspot Accounting messages;
*) added hits counter to hotspot walled-garden rules;
*) made demo mode work;
*) fixed bug - sometimes installation software was reporting errors were no error existed;
*) console - fixed local variables;
*) console - improved syntax error messages;
*) console - allow use of item numbers in scripts and without prior print;
*) console - order export by object type dependencies, use item numbers
where required;
*) fixed AR5211 channel list bug;
Whatâs new in v3.0beta2:
*) added support for Atheros PCI Express;
*) replaced console parser -
colored syntactic feedback,
line and column of parse error,
export coloring,
substitution inside quoted strings
(e.g. âaddr $($addr & 255.255.255.0)/24â);
*) line editor remembers last modified string when walking history. You donât
lose your command if accidently press âupâ;
*) F1 works as â?â in console;
*) references to one script may become â(unknown)â, will require manual
fixing of configuration;
*) fixed behavior of âdo=â arguments in console;
*) fixed - executing lines from console history did not reset history
position;
*) hotspot transparent http proxy requests now go through acl list of proxy;
*) autosupout.rif & supout.rif file generation now works;
*) wireless - added disable-csma option for nstreme mode;
*) wireless - added station-pseudobridge modes to do MAC NAT when
bridging over station mode link;
*) wireless - support for WPA2 pairwise master key caching to speed
up re-connect times;
*) wireless - access-list and connect-list can now specify signal
range to allow for connection;
*) wireless - access-list is now ordered and supports matching of
all interfaces, all addresses;
*) wireless - access-list entry can match in specified time;
*) wireless - access-list can specify client specific WPA or WPA2
pre-shared-key;
*) wireless - support for RADIUS accounting for both MAC and EAP;
*) wireless - support for RADIUS Disconnect-Request to disconnect
client with RADIUS request;
*) wireless - can now specify format of MAC address in RADIUS
requests;
*) wireless - include Calling-Station-Id (in format XX-XX-XX-XX-XX-XX)
and Called-Station-Id (in format XX-XX-XX-XX-XX-XX:ssid) in RADIUS
requests;
Whatâs new in v3.0beta1:
*) added support for SATA disks;
*) added initial support for SMP on x86;
*) added support for up to 2Gb of memory on x86;
*) fixed time matching in firewall rules;
*) added time matching to bridge firewall rules;
*) multiple ports can be specified in firewall as src. and dst.;
*) added support for NAT-T in IPsec;
Caveats:
*) dropped support for Linksys HomeLink PhoneLine Network Card (10Mbps over
telephone line);
*) dropped support for PCMCIA RadioLan;
*) dropped support for Wavelan/Orinoco wireless cards;
*) dropped support for Aironet/Cisco wireless cards;
*) dropped support for Atheros 5210 wireless cards;
*) dropped support for telephony package;
*) ISDN does not log called and caller numbers anymore;
some of previously accepted syntax now will not work,
syntax can change in next betas,
completion is not yet fully implemented;
*) matching for some RFC non conforming TOS values wonât work;
and v 3.0 beta i think
so get a lisance and upgrade
xezen, you are crazy =)
why not just give him a link to Changelog? %)
hehe , whats up man .. you write all of this
