A Mikrotik with a bridge-local with ether1 and wan1, and a dhcp server(different machine) connected to ether 1.
When i connect clients to lan1 they get an address from the dhcp-server but when i try to connect a client to wan1 it cant connect because it
doesnt get an ip. It works if i assign a static ip for a wlan client.
Is there anything i need to configure on the wlan interface?
Thanks for the answer but you are misunderstanding me.
The DHCP Server for our LAN is NOT configured on our mikrotik.
My Problem is that Clients connected to the LAN-Port of the Bridge(the DHCP-Server is connected there too)
get a DHCP-Offer, but on the WAN-Port of the same bridge, they dont.
Can you give a bit more explanation as to what you are trying to do here.
There are two options either you trying to setup a dhcp relay or you running both the dhcp server and the wlan clients on the same lan in which case you need to bridge the ports. If you can give us more info we can better assist you.
Okay, First Problem is solved.
Someone left an old router with the same ssid plugged in, wich caused the strangeeffects.
Now dhcp works if connected to the mikrotik over wlan.
The Problem is i can only connect if i disable any security.
If i activate Wpa/Wpa2 i always get
wlan1: disconnected, unicast key exchange timeout
