Problem with hotspot and user login
Hello everyone.
I have a problem in the hotspot with user login, I proceed to detail the configuration and the problem.
We have 2 routers and ONT in the company from the company that provides us with internet (Movistar), a router for 2 floors and another router for the other two floors. I have configured a Mikrotik RB4011IGS+RM router on the company’s router. It is configured with a hotspot with a captive portal, so that users can connect to the Wi-Fi network by logging in with users and passwords that I am creating.
Since this router does not have a wireless module, I have placed 3 MikroTik cAP ac Access Points that are connected to the Mikrotik router. The access points have the default configuration, that is, with DHCP and I have only changed the SSID of the Wi-Fi networks.
The problem is that everything works correctly but if I log in with a user with my mobile, then I connect my laptop and it automatically connects to the last logged in user, that is, I connect to access point 1, the captive portal jumps up, I log in with username and password, I have internet and everything is ok, I pick up the laptop, I connect to the same antenna and the captive portal does not appear, it directly automatically logs me in with the last logged in user, That is, my cell phone and using the username set in it.
I have been reviewing the configuration and everything is correct, I think the problem comes from the dhcp of the access point itself, since it gives me IP’s of the access point 192.168.88.x and not an IP of the router 192.168.20.x.
I think the error is that the access point only makes one request to the router, since it assigns the IP’s from its own DHCP, so only one request is made to the router’s hotspot, am I right?
Would I have to deactivate the DHCP of the access points so that they assign me IP’s of the router and so the requests go directly through the router?
yes, it removes the Nat and uses the access points in bridge. the authentication is hooked to the Mac address, with the Nat the clients behind the caps, the hotspot always sees the mac address of the cap
I have tried deactivating NAT on the access points and it has worked halfway, on the router that I have on floor 2 it works perfectly, it no longer automatically logs me in with the last username and password, but on the other router that I have on floor 0 it has not worked for me.
The captive portal appears and when I try to enter a user to log in I get an error that the username or password is incorrect, I have tried with several users and the same thing happens to me, I already think this is due to the configuration of the router that there must be something wrong, since I have another router I will configure it again and try with another router, so I rule out that they are not the access points.
