as it would appear I have a problem with the DNS-server(s) of my ISP.
I use two connections ADSL and behind works a network for nearly 80 clients. Sometimes are the connections at www very slowly and if I make a traceroute there are some timeouts at this moment. But it is every time from another board and at another time. Other boards are working fine at the same time.
Now I would try to use other, free DNS-servers, because I think that my ISP “plays” with his DNS-servers. My connections are working with DHCP from the ISP.
My question:
Can I configure other DNS-server-IPs simply in the WINBOX by using >ip dns settings and it will work so?
Or is it better if I make an own DNS-server for example BIND and if so, how can I integrate this at a Mikrotikboard?
From the traceroute it doesn’t look like it is related to the DNS servers, rather to instability
of the link. Anyway, if you want to use a free DNS server you can simply put the IP address
of the DNS server in /ip dns settings.
Since you get connected to the internet using dhcp-client, remember to remove the option
“use peer dns” from the dhcp-client settings. That option would overwrite your settings every time
your dhcp-client gets a new lease.
Instability of the link, I mean that the link drops connection. The connection is not stable, it keeps
disconnecting.
As you know, during a traceroute you execute ping to every router/server along the path (ICMP protocol),
it could be that some of those routers/server have been configured to drop any ICMP packet, thus
sometime giving you a false result of the connection.
Hmmm, all right, but if the traceroute (for examble to google.com) works exactly at the same time from 7 other Mikrotikboards in my network? All use the same gateway. This is what I do not understand.
I am using 2 gateways fron Tel. Argentina and one from Copaco Paraguay. Normaly the trafic is more stabil and I habe more bandwidth with the connections of Argentina, but this error also happens only there. If I have the problem of timeouts and change the gateway to Copaco the error is away here.
What do ICMP probes (ping/traceroute) timing out have to do with DNS?
You are right, fewi, but I thought so and that´s why I tryed it. The timeouts are only at the gateway of one provider…
Well, I will check sometings more and open a new topic, if I do not found the reason.
But anyway, the fact with the DNS-servers is, that it only works, if I put the DNS-server-address at the computer or the first router at my home-network.
If I set the Mikrotiks in ip dns settings it ignors that and all other users are working always with the DNS-server of the provider.
Why?
