I have setup a hotspot with mikrotik RB450G running version 4.11 software. I also have a freeRadius 2.1.9 server which works fine. The problem is that Mikrotik can not authenticate clients using my radius server. This is from mikrotik’s log
17:20:03 radius,debug new request 3f:3c code=Access-Request service=hotspot called-id=vHotspot
17:20:03 radius,debug sending 3f:3c to X.X.X.X:1812
17:20:03 radius,debug,packet sending Access-Request with id 23 to X.X.X.X:1812
17:20:03 radius,debug,packet Signature = 0x404a2d4966949dc5fc3107c685b0534d
17:20:03 radius,debug,packet NAS-Port-Type = 19
17:20:03 radius,debug,packet Calling-Station-Id = "00:1C:23:8F:9E:19"
17:20:03 radius,debug,packet Called-Station-Id = "vHotspot"
17:20:03 radius,debug,packet NAS-Port-Id = "eth3 HOTSPOT"
17:20:03 radius,debug,packet User-Name = "test1"
17:20:03 radius,debug,packet NAS-Port = 2156920848
17:20:03 radius,debug,packet Acct-Session-Id = "80900010"
17:20:03 radius,debug,packet Framed-IP-Address = 192.168.12.100
17:20:03 radius,debug,packet MT-Host-IP = 192.168.12.100
17:20:03 radius,debug,packet CHAP-Challenge = 0xa3657ff1f5e2ab8ce096f754e6d74f2e
17:20:03 radius,debug,packet CHAP-Password = 0xa5ceb1c383769b17f84337f2b5a7e98d
17:20:03 radius,debug,packet 6c
17:20:03 radius,debug,packet Service-Type = 1
17:20:03 radius,debug,packet WISPr-Logoff-URL = "http://192.168.12.1/logout"
17:20:03 radius,debug,packet NAS-Identifier = "HOTSPOT"
17:20:03 radius,debug,packet NAS-IP-Address = 192.168.1.3
17:20:03 radius,debug,packet received bad Access-Accept with id 23 from X.X.X.X:1812
17:20:03 radius,debug,packet Signature = bad 0x9a8d9d1e944358615435655b39c389ad
17:20:03 radius,debug received packet for 3f:3c with bad signature, dropping
17:20:06 radius,debug resending 3f:3c
I can check the account on the server itself and it is working fine:
# radtest test1 test1 127.0.0.1 0 xxxxxxxx
Sending Access-Request of id 8 to 127.0.0.1 port 1812
User-Name = "test1"
User-Password = "test1"
NAS-IP-Address = 127.0.1.1
NAS-Port = 0
rad_recv: Access-Accept packet from host 127.0.0.1 port 1812, id=8, length=20
and also the freeRadius log is like below, when mikrotik attemps to authenticate the user, it states that Accept message sent to mikrotik. I wonder why mikrotik does say it is bad?
rad_recv: Access-Request packet from host Y.Y.Y.Y port 48718, id=24, length=202
NAS-Port-Type = Wireless-802.11
User-Name = "test1"
NAS-Port = 2156920850
Acct-Session-Id = "80900012"
Mikrotik-Host-IP = 192.168.12.100
CHAP-Challenge = 0x525d30c725f67c5aa6a17e0e1cc2ad8a
CHAP-Password = 0xc3deed5b93614cd9062533c82ba81f46b7
Service-Type = Login-User
Wed Sep 1 17:30:04 2010 : Info: +- entering group authorize {...}
Wed Sep 1 17:30:04 2010 : Info: ++[preprocess] returns ok
Wed Sep 1 17:30:04 2010 : Info: [chap] Setting 'Auth-Type := CHAP'
Wed Sep 1 17:30:04 2010 : Info: ++[chap] returns ok
Wed Sep 1 17:30:04 2010 : Info: ++[mschap] returns noop
Wed Sep 1 17:30:04 2010 : Info: [sql] expand: %{User-Name} -> test1
Wed Sep 1 17:30:04 2010 : Info: [sql] sql_set_user escaped user --> 'test1'
Wed Sep 1 17:30:04 2010 : Debug: rlm_sql (sql): Reserving sql socket id: 2
Wed Sep 1 17:30:04 2010 : Info: [sql] expand: SELECT id, username, attribute, value, op FROM radcheck WHERE username = '%{SQL-User-Name}' ORDER BY id -> SELECT id, username, attribute, value, op FROM radcheck WHERE username = 'test1' ORDER BY id
Wed Sep 1 17:30:04 2010 : Info: [sql] User found in radcheck table
Wed Sep 1 17:30:04 2010 : Info: [sql] expand: SELECT id, username, attribute, value, op FROM radreply WHERE username = '%{SQL-User-Name}' ORDER BY id -> SELECT id, username, attribute, value, op FROM radreply WHERE username = 'test1' ORDER BY id
Wed Sep 1 17:30:04 2010 : Info: [sql] expand: SELECT groupname FROM radusergroup WHERE username = '%{SQL-User-Name}' ORDER BY priority -> SELECT groupname FROM radusergroup WHERE username = 'test1' ORDER BY priority
Wed Sep 1 17:30:04 2010 : Debug: rlm_sql (sql): Released sql socket id: 2
Wed Sep 1 17:30:04 2010 : Info: ++[sql] returns ok
Wed Sep 1 17:30:04 2010 : Info: ++[expiration] returns noop
Wed Sep 1 17:30:04 2010 : Info: ++[logintime] returns noop
Wed Sep 1 17:30:04 2010 : Info: [pap] Found existing Auth-Type, not changing it.
Wed Sep 1 17:30:04 2010 : Info: ++[pap] returns noop
Wed Sep 1 17:30:04 2010 : Info: Found Auth-Type = CHAP
Wed Sep 1 17:30:04 2010 : Info: +- entering group CHAP {...}
Wed Sep 1 17:30:04 2010 : Info: [chap] login attempt by "test1" with CHAP password
Wed Sep 1 17:30:04 2010 : Info: [chap] Using clear text password "test1" for user test1 authentication.
Wed Sep 1 17:30:04 2010 : Info: [chap] chap user test1 authenticated succesfully
Wed Sep 1 17:30:04 2010 : Info: +- entering group post-auth {...}
Wed Sep 1 17:30:04 2010 : Info: ++[exec] returns noop
Sending Access-Accept of id 24 to Y.Y.Y.Y port 48718
Wed Sep 1 17:30:04 2010 : Info: Finished request 1.
Wed Sep 1 17:30:04 2010 : Debug: Going to the next request
Wed Sep 1 17:30:04 2010 : Debug: Waking up in 4.9 seconds.
Wed Sep 1 17:30:09 2010 : Info: Cleaning up request 1 ID 24 with timestamp +20
Wed Sep 1 17:30:09 2010 : Info: Ready to process requests.
what is going wrong here?
