I using RB1100AHx2 v6.27
I have registry no-ip host, and add this script + schedule for run script
# No-IP automatic Dynamic DNS update
#--------------- Change Values in this section to match your setup ------------------
# No-IP User account info
:local noipuser "USER"
:local noippass "PW"
# Set the hostname or label of network to be updated.
# Hostnames with spaces are unsupported. Replace the value in the quotations below with your host names.
# To specify multiple hosts, separate them with commas.
:local noiphost "HOST"
# Change to the name of interface that gets the dynamic IP address
:local inetinterface "INTERFACE"
# No more changes need
#:global previousIP;
:if ([/interface get $inetinterface value-name=running]) do={
# Get the current IP on the interface
:local currentIP [/ip address get [find interface="$inetinterface" disabled=no] address];
# Strip the net mask off the IP address
:for i from=( [:len $currentIP] - 1) to=0 do={
:if ( [:pick $currentIP $i] = "/") do={
:set currentIP [:pick $currentIP 0 $i];
:local previousIP [:resolve "$noiphost"];
:log info "DNS IP: $previousIP, interface IP: $currentIP";
:if ($currentIP != $previousIP) do={
:log info "No-IP: Current IP $currentIP is not equal to previous IP $previousIP, update needed";
# :set previousIP $currentIP;
:local url "http://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP";
:log info "No-IP: Sending update for $noiphost";
/tool fetch url=($url . "&hostname=$noiphost") user=$noipuser password=$noippass mode=http dst-path=("no-ip_ddns_update-" . $host . ".txt")
:log info "No-IP: Host $noiphost updated on No-IP with IP $currentIP";
} else={
:log info "No-IP: Previous IP $previousIP is equal to current IP, no update needed";
} else={
:log info "No-IP: $inetinterface is not currently running, so therefore will not update.";
Then, i NAT port 81 for camera device.
Now, when i type user.ddns.net:81, browser go to the page of camera device → OK
But i just type user.ddns.net, browser go to page login router.
Why’s that when I just NAT port 81 to ip camera?
